Towing troubles
G
greenheadsled
24
7
Elkton MI
Im curious to know everyone elses experience on towing their 700, I seem to struggle no matter the situation and its not from lack of power from my truck, does anyone have any tips or tricks to help me out?
Thanks, Jim
allgm1
allgm1
1,049
1,484
New Hampshire
they are not the must aerodynamic rigs to begin with, not really much you came do except tow it and bite the bullet. oh and use "tow mode" if your truck has it.
G
greenheadsled
24
7
Elkton MI
I do use the tow mode, i guess i feel a 2500 with 400+hp should handle it better but maybe not
Reactions: nbomar
swsebek
swsebek
2,854
5,828
pa
Make sure you don't have the SXS too far forward on the trailer. Just a bit forward over the axels
Reactions: Deluxe700
G
greenheadsled
24
7
Elkton MI
You guys tow with the windshield on or off?
Hondoman
Hondoman
727
1,695
Texas
This^
I haul my p1k-5 on a heavy duty 16' tandem axle trailer and it tows easy when I have the engine centered over the trailer axles.
Forgot to mention, I'm towing with a 1500 and only 285hp.
66,162
I tow mine on a 20' car hauler. I pull it all the way to the front. The tounge weight makes the 2500 ride better. And the truck topper helps to break the wind up better. These rigs are a parachute back there. I also take the windshield off for long hauls.
allgm1
allgm1
1,049
1,484
New Hampshire
Really? try with a 1500 towing will take really take the wind from the sails. Windshield on unless its during the summer months when I take it off
I
infernored1000
219
262
Thanks, Jim
How does the trailer tow empty?
When was the last time you did maintenance, grease bearings, check spindles, wheel play, checked brakes?
Not trying to insult you by saying you don’t just something to think of. I had an issue with fishing line that had somehow worked it way in, like 500 ft of it and was causing so much drag It felt like it was pulling to the left side.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I tow with a 16 ft tandem axle trailer. I put what I think is the greatest weight of the P700 (about mid machine) over the axles. I invested in some really great tie down straps..I have the windshield on. I worry about all the force on the windshield and roof from the wind, but so far so good. As far as Power, I don't seem to have an issue, but it does tow different then when I used to have 2 atv's on the same trailer.
Reactions: Mudwing
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Didn’t notice an issue when towing the 1000-3 about 200 miles home in October when I purchased it with a raised 1500 GMC. Can tell a big difference when towing the equipment trailer with the tractor.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
I tow my 700-4 on a 6x12 single axle trailer. I can easily go 80mph in my Tundra. I've thought about removing my windshield but I've never done it. Oh and I usually drive a little over 2hrs to the trails.
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Thanks, Jim
What kind of truck and trailer do you have
G
greenheadsled
24
7
Elkton MI
2017 ram 2500 and 18' tandem axle car hauler
I guess i made it sound more dramatic, i can punch it and pass cars and cruise 75 but i just felt like 1500 pounds shouldnt even know its back there
G
greenheadsled
24
7
Elkton MI
Once the weather warms up i will definately do a thorough inspection, thank you sir
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Depending on where u load it on the trailer the 700 is lighter so maybe move it a little farther forward and with a windshield you will feel more resistance than with it open or no windshield depending on the gear ratio. You have a 1700 lb machi e and prob 2k lb trailer shouldn' feel it but every truck is diffeent I like feeling it back there so u know its still attached
sharp
sharp
3,757
14,955
Tennessee
Thanks, Jim
Check your electric trailer breaks. The break controller inside the cab might be going out and sending a slight surge to the trailer causing the breaks to drag and make the trailer feel a lot heavier. You will notice if you are cruising and let off the gas and the truck and trailer seem to slow down quicker than normal.
Rinconruss
Rinconruss
40
64
Lakeland Florida
I found a drastic difference between towing with or without the windshield on my P700. With the windshield on it was like I was dragging something behind me. Tow vehicle is 02 f150 w/4.6
Reactions: Plumber32
Mopower58
Mopower58
CST is the Best!
69,664
640,821
Crystal Springs,Ms.
Does the 2500 have a HEMI or a Cummins? Wind drag will affect towing as much as weight. Our Cummins never looked back on whatever we towed, the HEMI, as with all gas burners,doesn't tow as well.If you have a drive on lift gate with expanded metal wire it definitely has a LOT of wind drag.
