Traveller OG -- sold
Reactions: JACKAL
267,224
@joeymt33 Woohoo! getting the ole girl airborne! :cool:
Reactions: CumminsPusher
Can anyone guess the significance of the name "Traveller"?
I may change its name to Manuel. It does all the "manuel" labor around here......
72afcc8bd45f1e26300352656b08647a
C35fe714b01d2f4e800997c4b9b61364
B479862bdd0efea2295e2b95301e1c50
Reactions: Dp5hunter
Very old thread here. My buddy @DGann showed up with the pioneer 700 that I sold him back in late 2015. he brought it in the shop for some exhaust work, brakes, lights, switches, etc. it’s still a rock solid machine like it always has been.
Hey @DGann how about showing a picture of those lights we mounted.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
You must be workin him to hard...he dont ever come around anymore.
We were thinking about riding today but it didn’t work out. We are going to get a ride and hopefully in the next couple weeks.
That pioneer 700 is way to clean! But I know that he will solve that issue because it seems like every time we go out he finds a big mudhole somewhere.
lee
lee
Village Idiot
2,350
13,232
Springfield Ohio
Scared the s*** out of me when I saw the title of this thread.
What you sold Traveler!
Took me a minute to realize that was traveler 1.0
I like the numbering system. I may adopt it.
Here’s some other pictures of the damage.....
8788758bd7ee50659a50535b3c0b13be
6918f6b2f50d4bb2f1b9caaeca2a334d
This is the rack and pinion mount which is also cracked and pulled away from the frame a little bit
E562208268536b2cdc5d68da0df86311
We just used a flux core wire welder. Had to remove the tabs from the frame to straighten them out and then weld them back on.
7a54bc7384f5be01e227d3ffbd45d482
They are also welded on the inside of the tabs and the backside of the frame. From the factory they are only welded on the outside.
We added braces that goes from the lower part of the upper a arm out over to the rack and Pinion mount. It’s a small piece of angle that should add some strength.
There are holes in the upper a arm mounting tabs so we added some all thread through those holes to help tie them together. It will keep them from pulling apart but it’s not going to add much support if they try to push together.
Ad6e1d597941a43cdd51d2cab7719d0e
