Multi Tube frame rust protection
Mudder
Mudder
NTC Ambassador of Walls
11,382
84,889
Multi post to share info from a P500 thread on corrosion protection for inside frame tubes.
Google search for rustproofing tube frames found this product from an aircraft site. MIL spec certified for aircraft frame tubing. Many other forum sites (boats, car restoration, racing bikes) noted not to use foam due to moisture trap.
POLY-FIBER TUBE SEAL LINE OIL from Aircraft Spruce (creeps up around pipe) Just ordered a pint, $14. No promo codes currently available. Plan to use air compressor (liquid) parts cleaning wand to spray mist in SxS and ATV. We'll see how it works....Other stuff listed:
Corrosion Treatment from Aircraft Spruce
CC160A45 4973 4901 960C 32180CFADEDE
