P700 Uncomforable Seats
Riverrunner16
6
Kuna,ID
Just put 70 miles on my 2020 700-4, back was hurting after wards...anyone done anything to make the seats a lil more comforable ?
Also on pothole filled roads ride was pretty harsh (Used to drive an Artic Cat 550 four wheeler)..maybe a shock adjust would help that ?
Always run with the wife and I and our 3 dogs (150 lbs.) and dry box (30 lbs.) in the bed.
Thanks,
Scott
42,130
Air pressure? Makes a big difference.
The rear shocks usually come on 2nd from full soft, so you can go down a notch in back. You can also remove the rear sway bar, but you may not want that if you're doing a lot of road riding.
EDIT: Just realized your post centered around seats. Some people swear by flipping the backrest and mounting it upside down. Other than that, maybe some of those gel cushions? I find the 700 seats quite comfy, personally.
Riverrunner16
6
Kuna,ID
Thanks everyone for the ideas, I will try them out !
Scott
livefromthetree
livefromthetree
466
1,309
Mount Vernon Indiana
I flipped the back rest on mine a week or so ago. Not 100% sure it helped much or if I've just gotten used to the ride, but it will stay that way now.
4 bolts go back in with a little pressure and I went ahead and put a self tapper back in the center hole up top to keep it from rattling
Reactions: Riverrunner16
