P1000m5 UTVMA Front bench seat fit into Pioneer 1000-5(heavy modification)
Blaker3115
Blaker3115
55
225
I wanted to try something different and came up with this.
I’m sure there could be someone come up with a different mounting solution than I did but I decided to mount to the same seat Frame that was there for easy removal. One thing I would have done differently is not cut the full cushion out in the front ledge. I should have left around 7” still in tact from the front edge. I went ahead and put that piece back in to make it look better. Going to try and use some vinyl tape or glue it back in for a more completed look.
Below will be YouTube link videos for what I done to make it work. Not an easy mod but I feel was worth it for me and my family.
I’m happy with the comfort and quality as well.
64e06f49f2b0dd13fe752ccd55063979
Blaker3115
Blaker3115
55
225
Is the seat removable? Or with the belts installed is it pretty much stuck in there?
I used the one seat base to be removable. Just have to unhook the harness across top bar no tools required. If want to completely take out then just remove the bottom bolts of the harness
Reactions: Backwoods and ChadD
Jankyeye
Jankyeye
611
2,783
Tampa, Fl.
that's pretty sweet! good job
