![jak9922](/data/avatars/m/2/2072.jpg?1479423001)
Nice video. I notice you shift back and forth between 2 and 4 wheel drive on the fly!! That doesn't cause damage as the warning label seems to indicate?? Also, is that a four position rocker switch assembly on the dash?
that's my son lol hes always with meHaha, glad your passenger had a helmet. That limb popped him pretty good.
How do you have those switches mounted? Can you post a closer pic?yes I change 2-4-2 on the fly under no throttle and only in L-2 gear and those are 3 rockers and 1 usb charger on my dash
Exactly, use a Dremel not a Skil saw right? what's the difference between the cut out and what the housing frame covers, an 1/8 th. inch??? Say, just checked out your link, it shows four single box housings, you didn't use a single quad box?Amazon.com: Rugged Ridge 17235.20 Black Rocker Switch Housing Kit: Automotive
then trace out on your dash carefully cut and pop in lol easy peezy just remember cut small first then trim u can always take more off but cant put it back
Ok......I asked a few questions in that post. Can you elaborate some?I just trace it out then cut inside the lines
Thank you!On that link i sent u snap the switch brackets however many u want 2-3-4 once they are together place the back of the bracket up against your dash abd trace around the outside with a sharpie then gut it out with a dremel once done and its nice and tight push the bracket in it has little friction clips built in that hold it in place but u can always add a little silicon for added insurance
