Vikes79 longship rebuild thread
Buggyman
Buggyman
35,227
299,914
ne. ohio
Looks great, I’m still concerned that those Yamaha drivers are going to have different ideas about it however!
On the flip side…maybe the extra exhaust thrust is good for 30 hp? 🤷‍♂️
Screenshot 20240425 1808023
Vikes79
Vikes79
SKOL!
11,035
107,189
South Dakota
  2. Talon X4 LV
Here’s a look with the roof and the SATV flip windshield that was previously installed.
IMG 6363
The window has a ton of glue residue from some sort of protective adhesive backed plastic (it’s all over the plastics too). It’s so bad you can’t see out of it.
The stickers I’ll use my heat gun to gently warm up and remove but I’m really not sure how or what I can use on the residue that won’t etch or scratch up the poly screen….maybe crank up the temperature on my hot water pressure washer or use really warm dish soap and water, @SuperATV any suggestions?
I’m worried that something like alcohol will be too aggressive on it.
Todd627
Todd627
56,517
617,063
MI
Try peanut butter (easy @Backwoods & @J80 its to take the residue off the windshield).
WagginTail
WagginTail
1,484
5,479
SC
WD40 might work
Prntckt
Prntckt
1,049
7,228
Altoona, WI
Got the rear end squared away with the arms I straightened out. Took it for a spin and it for sure tracks better. It looks like both rears are toed in slightly….I believe this is normal for this type of suspension as power applied makes the rear toe out a bit…just what i remember from college mini Indy days…🤷‍♂️
View attachment 426188View attachment 426189
So I pressure washed the buggy with the rear suspension fixed. I then pulled the old Rops and test fit the new takeoff I picked up last week.
Much to my surprise, the front section fit perfectly, then the middle…and the rear as well! I was stunned as I thought I’d be beating the crap outta it.
Mrs Vikes79 thinks I should leave the Rops red and call the buggy Stepchild….
Yea or Nay ? What say you?
So its redheaded cheap bastard stepchild then...😁😁😁?
Seriously, your rebuild Is looking good.
ChadD
ChadD
23,282
233,356
Brown City
Try WD40 on a small area. I tried tinting lexan before and it bubbled from the gasses. WD40 took the residue off and it looks fine. Was a trick a decal shop owner told me.
Vikes79
Vikes79
SKOL!
11,035
107,189
South Dakota
  2. Talon X4 LV
I’m working in the shop now straightening the front upper light and fender structure…I’ll give it a try this afternoon. 👍
Vikes79
Vikes79
SKOL!
11,035
107,189
South Dakota
  2. Talon X4 LV
Drivers front took a bigger hit than I originally thought.
The drivers headlight bucket and that entire side ran into something that missed the wheel etc but still shoved it hard enough to bend the light plastic metal frame work and put a serious dent into the radiator. Radiator isn’t leaking and still is full…
Got the metal parts straightened, the plastic fender warmed up and pushed out.
Gonna start plastic welding bush fix style (torch, big flat blade screwdriver and zip ties melting) to fix the headlight buckets.
IMG 6363
IMG 6368
IMG 6369
IMG 6372
IMG 6374
IMG 6375
IMG 6373
Vikes79
Vikes79
SKOL!
11,035
107,189
South Dakota
  2. Talon X4 LV
Got the headlight bucket patched up. I heat the tip of a big screwdriver up with a torch to a light blue color and then essentially heat up and melt together a zip tie and the broken joints. Not as strong as original, but I’ve fixed a ton of plastics this way. You can use some aluminum window screen mesh for extra reinforcement if you like.
IMG 6376
IMG 6377
IMG 6378
IMG 6379
IMG 6380
IMG 6381
