Want bigger tires
Jeramyhsmith
Had my Pioneer for 6 months with over 700 miles. Casual riding to some good mudding. Time to get a big winch, light bar, bigger tires. Not too big, just need more clearance. Anyone have pics of a good set up and a lift kit?
K
kyhunter
127
There is a few lift kits coming out but you can run a 28" bighorn 2.0 without a lift gains about a 1 1/2'' ground clearance. Im running the bighorn original 26/10/12 & 26/12/12 which measure out to almost a 27". Best thing Ive done to the pioneer so far is changing the tires and wheels.
I
idahohntr
141
5
Would like larger tires as well, however if I did that it would not fit in my garage with the hardtop on :x
K
kyhunter
127
I'm not sure about running 28" but I can fit in a 9x7 garage door without rubbing.
Agree with kyhunter. You can see from my avatar I have a light bar on top and I can get in a 7'H garage door easily with stock tires. 28" would only add 1.5" of height. If you are not entering the garage on mostly level ground it might be an issue. ie:basement garage with a slope down to the door. The rear of the machine would be higher than the front and hit the frame as your entering.
K
kyhunter
127
I've looked at Light Bars but I'm afraid It'd get ripped off after one ride.
BigRiver put his on hood/dash in front of windshield. Wish I'd thought of that before I put holes in roof.
