P1000 Water in Gas
russknight
russknight
1,910
7,506
Perry Florida
Welp, sunk my buggy and lo and behold found out former owner snorkeled everything except the fuel tank. Is it pretty easy to pull the fuel pump? I want to disconnect the fuel line from the injectors but the connection is in a bad spot to say the least, plus it looks like you may have to have a special tool to disconnect it. Any input would be greatly appreciated.
Mark in Northern Iowa
465
2,081
Floyd County, Iowa
kramnella.wixsite.com
I have never done it, but you know others will chime in.
The best I can do is post a link to a digital 2016-2020 Service Manual.
Found this page 7-6
1649190484349
and this page 7-7
1649190523958
Have a good day
JenElio
JenElio
64,974
608,267
Loxahatchee, florida
I helped my buddy after he went scuba diving with it 😂😂
We vacuumed out the contaminated gas tank, removed injectors and turned the engine quite a few times while vacuuming as much as possible everywhere. Been over a year since and no problems.
russknight
russknight
1,910
7,506
Perry Florida
Water never entered the engine. Gas tank was not snorkeled and let about 2 gallons of water in the tank. Going to pull the pump assembly, clean out the tank, and disconnect the fuel line from the injectors to purge it. Think I'll be good to go then.
russknight
russknight
1,910
7,506
Perry Florida
Pulled the fuel pump, drained and cleaned the tank today. Was able to remove the lock ring with a hammer and screwdriver. Ordered the correct tool from Summit to re-install it.
russknight
russknight
1,910
7,506
Perry Florida
Received the tool yesterday and re-installed my fuel pump assembly. Took that aggravating overfill tube out of the tank while I was in there. I was able to access the quick connect fitting at the injectors by removing the seat back. Those things are a real pita.
