Scrappapotamus
The Scrappapotamus
390
1,925
Midway KY
  3. Talon R
  4. Talon R LV
Currently in the garage taking measurements to try and figure out why my RR tire is wearing so fast... pressure is good, I'm not ripping donuts, brake is not dragging... so now I'm looking at the toe in/out
Turf Mode
Reactions: Backwoods
Scrappapotamus
The Scrappapotamus
390
1,925
Midway KY
  3. Talon R
  4. Talon R LV
In turf mode, only one of your rear wheels pulls. The other free wheels unless you diff lock. Depending on your driving habits and surface, I could see the one tire wearing more than the other. A 2 wheel drive pickup that is driven spiritedly will wear one wheel quicker than the other
P1K5Dave
P1K5Dave
2,166
8,094
Petoskey, MI
stays in turf mode most of the time until I need the locked rear end... figured out that it's more than an inch toed in 🤦‍♂️
Just to be clear, we're talking toed-in here, and not negative camber?
P1K5Dave
P1K5Dave
2,166
8,094
Petoskey, MI
toe in, the front of the measurement across the front of the rear tires is 1-1/8" less than the measurement across the rear of the rear tires.
Ok, yeah - sounds like maybe a bent arm. Even if your hub bushings were completely shot I dont think it could be off that much.
Jankyeye
Jankyeye
524
2,262
Tampa, Fl.
Added a winch remote disable switch. Just in case.
IMG 7535
Jankyeye
Jankyeye
524
2,262
Tampa, Fl.
where are you guys getting these extended latches? TY
I have some black anodized now. If anyone wants to send theirs back to me and get it done it would take about 2 weeks after I get it to get them back to you.
Fits in $7.25 flat rate USPS envelope, be sure to bubble wrap well so no damage is done in shipping.
Cost $32 total, Paypal friends and family to [email protected] . $25 for the black anodize and $7.25 for shipping back to you.
Please don't ship until we have touched based, I don't want to get them 1 at a time. Hoping if people want this done to get a few to send to plater at the same time.
Send to
WFOSXS
40107 215th Ave
Goodhue, MN 55027
Thanks
O
ob1jeeper
94
267
53
Arizona
Not exactly true. Just like the car/truck you operate on the highways, it is equipped with a differential, which applies equal power to both driven axles (tires), UNTIL one has ENOUGH less traction due to surface variations (or mud/snow/ice, etc) than the other, which will cause the one with MORE traction to LOSE power, as the less traction tire will begin to spin. If the spinning is uncontrolled, you will stop moving once the kinetic energy of original vehicle movement is used up.
RacinJasonWV
RacinJasonWV
WV
I didn't know about the one Jankyeye showed. The one I purchased is detailed in this thread.
Dirtstiffs-1000
Dirtstiffs-1000
1,555
5,660
hondasxs.com
Honda OEM Mirror mounts with soft upper doors.
These could likely work with any mirror' mount bolt pattern.
Contact @tjoreo for a great engineered solution to mirror mounts for Honda Soft Upper Doors.
These 3D printed mirror mounts are made specifically to fit your Honda Pioneer and Oem soft upper doors.
The quality is excellent and the design is intuitive to real world accessory fit.
Made by a forum member for the benefit of us all.
Dirtstiff approved!!
Thanks again!
20240316 173522
20240204 154404
