hemifoot
went sniffing around the stealership today to see if my camso tracks were in,really i was just a little bored and had a touch of cabin fever,saw they had some new 2020 p1k's in.have to say the new brown colour is really fugly.the '20 green rubicons looked pretty sweet tho.also picked up a small roll of carbon fiber wrap.planning on installing a round marine stereo like i did in my boat.plan to drill the holes for the head unit and a couple switches,drill out the rivets on the dashboard warning plate,wrap it and install the stereo/switches and pop it back on with some black anodized bolts instead of rivets..https://www.amazon.ca/Ignition-Rock...307&s=gateway&sprefix=rocker+,aps,215&sr=8-69
hemifoot
well,my tracks finally showed up.friday i'm heading up to the cottage to drop them in the workshop then me and the redneck gang are heading up the gold rush trail and doing some shooting and some skeet blasting along the way.my brother just finished a nitrous powered hemi cj he's itching to break.
Reactions: DanDan
hemifoot
finally got around to putting together a breakdown bag.i have one in the ram for offroading so i figured i'd put one in the honda.i travel alone so i filled a hilti tool bag with my viair compressor and plugs,channel locks,vice grips,multi driver,some coated baling wire,duct tape,small hatchet,small tarp,small first aid kit,snatch blocks and lifting straps,a couple bottles of water, and a bbq lighter and zip fire starter cubes,bear spray,mini mag and spare batteries.the more i adventure out the more i'll add to the bag.
CASTRATE
CASTRATE
77
350
53
NE OKLAHOMA
Added a S&W model 29 & 629 to plink a little. Ran some 300 grain hardcast flat nose that are a little on the hot side, & a couple of them made it through about 8" of wood.
.....then got stuck
20190727 122825 20190727 124351 20190727 145911 20190727 153016
Dirtstiffs-1000
Dirtstiffs-1000
1,574
5,738
hondasxs.com
Mudbusters XL
If I had it to do again. I'd use push pins wherever I could. I used them exclusively on the front.
I also used a heat gun on the rear flaps so the rear doors have no issues.
Hope this shortens my cleanup time.
Jim
20190804 111531 20190804 110316 20190804 112512
Reactions: DanDan
G
graybear
118
318
East Idaho
I added some dynamat to the back side of the seat bottom and also added a merino wool sheep skin to the bottom seat cushion. I have ridden thousands of miles on my GW with the wool covers and they feel cooler and offer added cushion. I think this should eliminate any heat through the seat bottom that I feel. It slide under the two straps. Now if I could find my fuzzy dice.
IMG 1993
Dirtstiffs-1000
Dirtstiffs-1000
1,574
5,738
hondasxs.com
I have to say I'm totally impressed with the quality of Honda's air box and clean air plenum.
Last weekend we went for a 75 mile in the high desert. The dust was mostly unbearable the whole ride. All the family and wheeler were covered in heavy dust all day long. I was sure the air filter and clean air plenum would be choked with dust..
To my surprise; removing the filter was butt simple, taking only a few minutes. But the best part is the filter still looks pretty new inside and out and the plenum or airbox interior, was spotless.
20190830 120951
Sr56
96
284
53
Murfreesboro
Finally got around to adjusting my steering wheel so it’s not pointing at 2 pm when going straight. Popped the cover off and saw the brake nut was on the threaded column just enough to barely engage the nylon. Was just about off. Probably would have if the center cap wasn’t there. So with the nut barely on, there was about one inch of play if you pulled up on the wheel.
I understand this is supposed to be a dealer checked item for quality control. Like someone else posted, the dealer sales person drove it up on my trailer so I didn’t notice the issue until 2 days later. This dealer was one of those high volume places with much lower prices than any of my local dealers. Now I know why.
Other than that issue I am so glad I bought the 1000-5 deluxe.
Next are full skids, winch, windshield, and rear view mirrors.
A
AZ123
Little high lift jack install today 42” inch I suggest 36” as it may effect head lights a little
279732E5 A2B6 4F87 A200 130704AF7FF3
ProudDadOf5
ProudDadOf5
3,113
24,132
Winfield, WV
  2. Other Brand
Got my box of mirrors today.. Driver, passenger and rearview.. Definitely looking forward to putting them on!!
ProudDadOf5
ProudDadOf5
3,113
24,132
Winfield, WV
  2. Other Brand
Proud Dad — I need to get mirrors also. Which ones are those? Thanks
The set I have are “Chupacabra Offroad Mirrors” Hope this helps ya bud..
