What did you do to/with your Talon today?
A
a94cobra
44
95
TX
  1. Talon X LV
I bought this one. Car Ignition Switch 12V RFID Engine Start Push Button Keyless Entry Starter Kit | eBay Pretty cheap. It comes with two transponders(like a key fob). You put one near the sensor and it beeps. Then you can start it. After you kill it. It waits 15 seconds then beeps again. After that it's locked without using the key fob again.
I just like being different.
I think you might even be able to use other transponders with it also. Like program a set of car keys. Not sure yet. I just got it installed and working.
Reactions: 906UP
PapaC
PapaC
55
334
53
W. Wa
I put this on-
74A6B5F5 6003 4F28 A0BD FA572ABBA6D9
00BC0153 F5D5 4F54 B68D 3BD9B0B200AE
Moab_Marty
Moab_Marty
30
35
Moab + Western CO
I bought this one. Pretty cheap. It comes with two transponders(like a key fob). You put one near the sensor and it beeps. Then you can start it. After you kill it. It waits 15 seconds then beeps again. After that it's locked without using the key fob again
Thanks for the answer, however I did not see what product "this one" refers to.
Reactions: Gohonda2
PapaC
PapaC
55
334
53
W. Wa
That's a good looking light bar and the curve is 'just right'. Link?
Choose the 30” curved in the drop down menu. When I first mounted it on the roof it was a little shaky, so I went to the hardware store and bought some rubber plugs, drilled a 1/4” hole through, sanded a curve in the fat end, wedged them between the rops, and roof, then used a self tapping stainless bolt to snug it all up. Came out nice and solid. Pics -
D3F8835B 7819 47C3 94A8 C5CBB98046F9
F6F71FF4 F91A 4953 A375 DEFF402F7C6D
Reactions: Smitty335 and CID
103,727
Got some fingernail clippers and trimmed them…
  • Haha
Reactions: toddvdh and CID
5,048
22,627
When I bought the Talon, I had the stealership install a Warn winch. This made me realize that I really should have a second battery to run the thing. It took longer than I'd hoped but I'm happy with the end result.
Having only seen a suggestion that it shouldn't be right behind the radiator and would fit behind the plastic firewall, I didn't have much to go on.
First up, the battery tray itself. I couldn't hold all 4 pieces square, so I made a 3/4" plywood jig. About welding - all welds shrink and they do it in all 3 planes, allow for that when you're building things or you'll have a lot of welded projects that aren't the size you wanted. It surprised me how hard I had to beat the jig to get it out of the tray.
1660618569285
Not knowing where I was going, I knew that I'd have to put the battery in place several times during the prototyping. Being retired, I felt a cardboard mock-up would be easier to work with, boy howdie, was I right.
1660618712842
Because batteries don't like vibration, I made the tray big enough to allow room for a double layer of inner tube. Trimmed to size later.
1660618812373
Front edge wraps around the frame tube -
1660618890478
Rear threaded rod hangars are welded into the angle - I used 5/16" rod.
1660618977815
One of the last trial fits. My 2021 had a Live Valve bracket welded in where the lower right corner of the battery tray is, it got the preferential Sawzall treatment (the 2020 didn't have that bracket). The large wiring harness in the lower right corner was on top of the round frame rail and had to be moved under it, that necessitated learning how to release the 3 plugs that live behind the RF shock (the tabs on all 3 need to be pried outward).
1660619035840
This is the Live Valve bracket I had to remove. Photo thx to JumptChaneAZ.
1685588527818
The harness at left/center that has to be moved under the frame rail -
1660620874833
Further out for a better idea of 'where' -
1660619103155
Pre paint -
1660619223841
The paint isn't that bad, the metal is (and lighting) -
1660619306846
Finally :oops: ready for the battery -
1660619428659
Thanks to @Talon19DC for the alum angle idea, I wasn't sure where I was going to put the isolator.
1660619552564
And the tests, key on, engine off shows both batteries at standing voltage.
1660619663866
Right after start-up, isolator isolating, starting battery is getting priority.
1660619723503
Once the isolator sees the starting battery is fully charged, it adds the aux battery to the charging circuit. The connection happens quickly, only a few seconds.
1660619862866
Isolator energized, batteries connected -
1660623099562
I used this battery because @PaulF recommended it awhile back -
1660662913728
906UP
906UP
13,114
122,426
da Yoop
The harness at left/center has to be moved under the frame rail -
Pre paint -
Excellent work, I looked at putting mine there as well but then found a good deal on the Honda wiper kit so that space was taken
  • Wow
Reactions: CID and Smittyp
scottkooch
scottkooch
66
238
SO MN
  1. Talon X4 LV
Pre paint -
Looks good CID. If I find that having my 2nd battery behind the radiator shortens the battery life, I my have to follow your lead and fab up something similar.
5,048
22,627
Well, that'll suck if I ever choose to add a wiper. Good point for those following along. 👍
5,048
22,627
My Talon finds a way to loosen the two battery terminal bolts, not much, but some. I had to tighten them again today, no trouble indicator, just preventative maintenance. They're only 6 mm so don't go ape on them thinking you'll only have to tighten them once.
Reactions: Smittyp
5,048
22,627
I don't like posting bad pictures but I hit 8000 miles today. I took 3 pics and all of them suck. :(
I Hd7pDnB XL
I was here when it happened. 😍 That's Red Cone straight ahead descending down to Webster Pass.
I FjvSgHx XL
F
Firedad
46
103
Reno, NV
  1. Talon X4
Working on full enclosure, still need to do lower doors tomorrow. Lost my side mirrors and ability to add cubes on the A pillar. Need suggestions for both.
81DB93EE 89FA 4C17 9BC6 2BBA6CB2BAC5 36EC976E A1B2 4669 91BE 89762CD0624E
5,048
22,627
Harbor Fright Ammo Can - this has been done but all I've seen is where, not how.
So, here's how I did it. For the purists, all fasteners are SAE because that's what I've accumulated over a lifetime, so sue me. :p
I started with locating the box where it's going to sit, checking for clearance issues. Thanks to @PaulF for mentioning that the upper trailing arm swings in at full droop, something I hadn't allowed for. So I jacked it all the way up and measured again.
Paul posted his details here, including watching for clearances -
I found that 8" outside the motor mount frame rail put it where it would clear everything. So I started with cutting the two 1" angle iron pieces to length, they aren't the same. Then I fitted them to the ammo can. Since I want to store a 100' x 3/8" winch line in it, I decided to use carriage head bolts because the heads are 'softer' to a nylon rope. In order to keep them from spinning when tightening the nylocks, I squared the holes in both the ammo can and angle iron. It was a lot easier in the sheetmetal box than the 1/8" angle (duh :rolleyes:). I've done this for several projects over the years and have the proper sized square file.
Once the angle iron was cut, drilled and squared, I bolted it to the bottom of the ammo can, measured and cut the joining strap and welded it in (crooked :oops:) but close enough. Measured 6 times and it still moved. :(
The ammo can -
Step one thru 60. I don't normally grind welds but needed a flat surface, soooooo ....
1662244638511
All the parts, pretty simple -
1662244792616
This hole was a b!tch because of the skid plate gusset on the left, even my angle drill couldn't get a straight shot at it. I used a 3/32" pilot drill (short, so better attack angle) and then a 1/4" which stayed true to the pilot hole. I picked this location by attaching the small pre drilled angle bracket to the rear angle, putting it in place (marked earlier) and using that as my template to draw the hole exactly where I wanted it, up and down, front to back.
1662245085845
I intended to drill that hole straight through the frame rail and use a long bolt with a nut on the inside but because I couldn't get a straight shot at it decided to try this. In hindsight, a whole lot depended on this idea working, I didn't have a backup plan. I welded a 3/8" x 1" strap on the head of a 1/4" bolt (yes, SAE 😊) betting it would keep the bolt from spinning while I tightened the outside nylock - there's absolutely no access to the bolt head inside the frame rail (hindsight - unless you drop the skid plate). Test fit to see if I made it long enough, barely. I welded the strap flush with the far side of the bolt head and should have put it half way across.
1662245428302
Here you can see I could have moved the strap 1/2 the diameter of the bolt head to the left, not flush to the right. The next leap of faith, how do I fish that bolt into the frame with only a sliver of access (hindsight - drop the skid plate).
1662253150014
After moving the string to the very end threads, I started by trying to gently tug it into the hole and pull it into place with a magnet, no workie. So I gave it a couple of light, quick tugs, like jigging and damned if it didn't jump right into the hole. I was shocked I tell ya. :oops: That's a 1/4" bolt in a 1/4" hole, I don't drill clearance holes. The black, making it look larger is the black paint on a q-tip that I stuck in there to inhibit rust.
1662246008336
Next lesson, don't do this -
1662246193866
before putting this bolt in. And it won't fit unless you take the nut out of the way, so all the way off. It was a perfect opportunity to drop my carefully fished bolt back into the frame but I didn't. :)
1662246296876
After putting the box in and out a few times, it marked the high point (center) of the outer frame rail and that's where I put the 1" tie strap between the two angle end pieces. 6-11/16". This is also where I measured 8" to the outside of the ammo can. Because the motor mount is in the way, the hole above the tape measure couldn't be in the center of the frame rail but there's room for a nut underneath and that's all that matters. The frame rail is arched right there, so I was able to get a wrench underneath to hold the nylock nut. That's not the case at the other end (just out of the bottom of the photo).
1662246880618
Trial fit and overview. I decided that I'd rather use two hose clamps than sheet metal screws into the thin frame tube. And they'd have to be flush/countersunk, harder for me to get properly tight anyway. You can see my square holes for the carriage head bolts here. I mentioned the two angle iron ends were different lengths - the front one spans the frame tube but the rear one just catches the edge since it didn't get a bolt down thru it. The corner on that one had to be clearanced to fit under the motor mount.
1662247031225
Ready for the ammo can. I hammered the two hose clamps flat to better fit the bottom of the box.
1662247305295
The R-clip was Paul's idea, I added the wingnut and luckily, got the small hole drilled in exactly the right spot for a tight fit. You can see that the angle isn't tight to the box, I used washers at all 4 corners between the box and angles so I wouldn't distort the box when tightening. You can see a little of the box's original OD Green peeking thru, not compatible with my red on white Talon.
1662247444796
Other dimensions - 1-7/8" center to center -
1662247732136
3-7/16" front of frame rail to center -
1662248572258
Contents - barely fit but I was able to force in an old towel to help protect from abrasion.
1662247898259
There might be room for one soft tie with the towel, I'll see after it settles in.
1662251599277
And the only time it will ever be clean - :(
1662250892623
