What Mods are on the list after this Takeover
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
One thing about Takeover is you get to see a lot of other machines and ride along with them on the trails... this usually results in many members walking away with a list of To Do’s for the next year.
After this Takeover what are your have to, going to, want to - do items.
For me - I am pretty happy with where I have my rig - I do anticipate having to get new tires by the end of the year so I was watching performance on the trail.
I need to lighten my load by reducing even further what I carry.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
SATV ball joints on the way. Also ordered Talon tie rods to retrofit if they will. Heims in the front upper and lower SATV arms with 2 mounts up top vs the long bolt. Finish the flatbed. Try not to wait till 3 days before Takeover to get my rig in the shop to get it ready haha.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I am definitely adding a left and right tie rod end to the spare parts - probably not carry when in a park but on trips like Tackett will make sure a pair is in the group.
As for changes.. I’m pretty happy with mine. Need to figure out the rear axle issue a little deeper and might do some suspension tweaking with different springs. I’m still on the fence about a custom cage and the IGR. Have some new rubber mat material to replace the mud busters. And I may add a little more distance light to the front bumper. Only other thing is the sound system.. maaaay have to go with a wet sounds and sub.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
My list for next years Takeover
1- sell/ trade in 3seater for a Wolverine
2 - update 5seater
Fox shocks
Mudbusters
Underdash storage
2 way radio
Power commander/ auto tune
Rear winch
Harness system
Fire extinguishers
3- Hammock system for trail side camping
Pretty sure the 3 seater fox shocks might be better for a 5 unless your hauling a lot.
Re wire everything. I want all my switches on one panel so I can regain the cubbyhole beneath the switch panel.
Been thinking about making some rock sliders/tree kickers
Extend a arms and remove the wheel spacers is on the list but it has been put off because it would require four new axles
Remove factory thermostat and put in my own in line thermostat for summer riding.
Figure out a way to do an inside the roll cage mounting points for the soft top. I get tired of breaking it loose rubbing the ground and trees.
Change out the LEDs in the stock headlights for amber that I hope would be better for rainy and foggy conditions.
After seeing the tree kickers hang on some of hat stuff at Tackett I’m undecided on adding them to my angle sliders.. I highly suggest the little phoenix for the money... it’s simple and small and tough!
What’s a little Phoenix?
Rewire with Switchpros and a new panel from mystic, better fan underseat with a built in adjustable stat, rework my accessory mounting so weight is lower, another pair of X5 on magnets like @JTW, power commander after seeing the grunt you got right off idle that helped in technical terrain, forced air helmet my boogers are still black from all the dust.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Agreed - I just need to find a local friend that welds or learn how. I brought 12 extra bungee's (cheap ) to replace ones and ran out.
I also want to figure out a cap or something to cover the square metal edge where the back and front cage come together. maybe I'll just grind the edge down as I got hung on a few trees. may try to built a cap out of a 90* pvc elbow.
