What's the biggest tire... Wrong answers only! --- Test thread.
Solution
toddvdh
63" paddles on stock Pioneer 1000-5
Pics or it didn't happen right? I have a flip up windshield, upper doors and soft cover over the rear.
Rightspots3amazonawscom2Farchive2Fsherp atv 7
Coeus
Coeus
Major General
58,823
588,745
Signal Mountain, TN
  2. Talon R4 LV
The left and right spacing isn’t the same as regular posts so the individual posts don’t stand out as much
CCD99541 5AF1 4386 90E5 EC7856B0AA35
Also, now that no answer was selected the view is better. When an answer was selected it was hard to tell the winner vs regular posts...
I’ll have to check this one the desktop tomorrow to see what that looks like
63,702
Only the poster can mark the solution?
and then once a solution is chosen seems like people can still vote? Even downvote to negative?!
Ya. Only the OP can mark the solution... Maybe an admin can. Not sure as its my post.
I'll have to compare the spacing. I'm not really noticing a difference. I'll load another phone tomorrow and check.
thanks for your feedback.
For now.. its bed time.
NTCPrezJB
NTCPrezJB
President of #NTC
100,763
900,324
Canton, OH
I’ve found that lining your fenders with 40 grit sandpaper resolves tire rub .... eventually. To expedite the process you can wire up hot tire knives to the nearest edge of the fender well (usually the lower rear portion for front tires and lower front portion for rear tires).
Pro tip: crossing a fresh lava flow will yield even faster results.
Ridinfool
Ridinfool
36,145
386,040
Western North Carolina
If you run 33’s on the front and 27’s on the back you glide right over any obstacles with ease, and if you hit a deep mud hole your buggy will be nose up and skim effortlessly across the mud.
NTCPrezJB
NTCPrezJB
President of #NTC
100,763
900,324
Canton, OH
Tires purchased through the club store with code #NTC have a lifetime guarantee against flats, punctures, wear and getting stuck. The President of the NTC has personally bought me a spare because I used the code.
