P1000m5 What's your winch pick?
  • Thread starter gabrielmarciano
  • Start date
G
gabrielmarciano
9
Point pleasant WV
I have had great luck with these in the past.
1000-5
9a5b6452a364582ecc0175e0572bdc5e
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I have the Superwinch Terra 45. When I first got I did not expect to use very much and a dang sure did not plan on using to help winch up the final part of a hill a time or too. I have been very happy with. Only exception being where I filled part of the free spool switch area up with mud - It still worked - just was harder to turn until I got cleaned out. I would not hesitate to buy again.
G
gabrielmarciano
9
Point pleasant WV
Ditto, great winch.
Has warn ATV winch quality improved? I have had two of them fail. One lost all internal lubrication and blew up, other the mounting points were so week that they failed.
In my opinion and from my experience, the Chinese ones are just as good of not better at a fraction of the cost.
Had 3 venom brand units since those two failed warns and have had great luck with them. One on front was used was used for plowing.
This brings my second question. Anyone have or seen a rear mount for a winch on the 1000-5? I had a winch on front and rear of my RZR and it helped a lot of times to have one in from and one in back.Cc3f8ac33bfcd7892f05162f98e74fc7C7d0e72bc6ded5b0730d265bff16c607
Reactions: TimG and sharp
This brings my second question. Anyone have or seen a rear mount for a winch on the 1000-5? I had a winch on front and rear of my RZR and it helped a lot of times to have one in from and one in back.View attachment 120718View attachment 120719
@knuckledeep also makes one.
This is DIY
E7F929C5 8A15 4ACC 9D42 EEC65A509B94 7304AAA5 8251 4DF1 85E0 4E59BED8E98C 4A75ABAB 76A5 4E0F BA97 CC17A26A188C F7985F82 C4C6 4898 9247 A5D0BE1BBD8F
A
Average_Joe
887
3,038
Gainesville, Fl
  2. Other Brand
I have used and abused my superwinch terra 45 my next SXS I will use the Warn Axon 45rc it's small.
sharp
sharp
3,757
14,955
Tennessee
Warn Axon 45s here
Reactions: TimG
E
elkguide
3,377
7,963
Vermont
I use my Warn for plowing snow and other than going through cables, I have had no issues. I was concerned that I might blow it up when I used it to pull a not running 8n Ford tractor onto a trailer but it did so well that I did it again later with another dead tractor. So I don't know if they are having issues but mine sure hasn't.
Reactions: sharp
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
@knuckledeep how much for this bracket? I have the hmf exhaust already.
I could make one like that out of 1/8 in plate steel prob be 50 shipped and with mount bolts that was @ohanacreek design if he doesnt minded me copying it
nbomar
nbomar
4,416
17,854
Springdale, AR
He doesn’t mind... :) i would like one. I can get it from you at takeover if you could have it there?
Party on Wayne!
I stole the idea from someone else and cleaned it up. I made one for someone since I had a spare winch plate. That is ¼” and it flexes.
