P1000 Will it ever end?
SuperATV
SuperATV
1,249
8,687
Madison, IN
www.superatv.com
Oooooh. Ed Zachary!!!! 😂😂😂
seijirou
seijirou
66
710
83
Kaufman, TX
  1. 1000 6 Crew
Fuse block!
Then I realized I wired it up as constant power 🧐
Ordered the ignition power pigtail from the shop and a constant duty cycle solenoid, so I'll change it to ignition power this weekend. Or perhaps add a DPDT switch so I can toggle either way.
20240502 195814
seijirou
seijirou
66
710
83
Kaufman, TX
  1. 1000 6 Crew
Good Lord, I just found the club store has the perfect DPDT switch for this. Club store getting all my money 🤑
-Bear-
-Bear-
NTC Master Fabricator
8,329
91,088
Black Hills, SD
www.facebook.com
  2. Talon X LV
Make sure to get the stinger relay with that along with the dual batteries, best upgrade I ever did to both my Honda's
seijirou
seijirou
66
710
83
Kaufman, TX
  1. 1000 6 Crew
Continuous duty relay and the key on pigtail showed up today so they're in. Honda provided a convenient hole to secure the relay with a friction pin. Not much I enjoy more than a convenient hole.
Aux/Key On switch should be here in a couple days to finish it off.
20240503 154242 20240503 154305
seijirou
seijirou
66
710
83
Kaufman, TX
  1. 1000 6 Crew
Aux/Key On switch showed up today! Also some stickers and schwag.
1715050361788
Started with making a harness to the switch.
1715050392088
The other end gets a 6 pin Deutsch DT connector (really an Amazon JReady knockoff but they work excellent)
1715050426052
1715050468636
Mostly finished. My wire up is a little bit of a hybrid of the diagrams from another thread on the forums here. I want the Aux light on when switched to Aux, but I want the Key-On light on only with the headlights. I have everything done except the headlight connection so I left the zip tie loose for now.
1715050492002
1715050510139
1715050526193
1715051818504
seijirou
seijirou
66
710
83
Kaufman, TX
  1. 1000 6 Crew
Doing the headlights side of the switch backlight was the least straight-forward part. The trick is to have power to the switch for both low and high beam, while keeping low and high beam power separated on the UTV side of things. Honda needed to do the same combination-with-separation for the tail lights and has a special double-diode in the fuse box for this, with the combined output being a brown wire. I was originally going to use this brown wire under the fuse box but I really didn't want to disturb any of the factory wiring so decided against it. Instead I decided to duplicate the effect; there's a connector just to the side of the fuse box that carries the individual high and low beam power in a 6-pin connector. I ordered the same kind of connector from the club store and made a jumper harness that goes in-between the factory connection and connected 2 diodes together on their cathodes, and one anode to low beam and the other to high beam. The combined cathodes are then hot whenever either low or high beam are on, and then that is carried to pin 10 on the switch.
1715291406332
Key on headlights off
1715291446450
Low beam
1715291473103
High beam
1715291493221
