P1000 Winch install: Where to install the wired port
mjleblanc
31
76
Camas, WA
I have the Warn VRX 45-S, everything is installed and tested, works great. However, As I am locking everything down, I need to decide where to install the external plug port for the wired Warn controller. I haven't seen any mention anywhere, so I am just tossing it out there....what is the best location for this port?
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
I just tucked mine under the hood it is there if I need it but never use it, the actual in and out switch I mounted under the dash where I can get to it easily that is what I use when I use winch,,,,
Reactions: BWAF and Ohio4x4
Ohio4x4
Ohio4x4
I brought the dishwasher
1,502
15,101
I also mounted mine under the hood. It's only there for when my dash rocker won't work.
7,197
27,839
Installed my first one inside glove box, second time installed a dash switch and port on upper left front fender. This last time only use a dash switch and wireless remote.
57,532
I put mine where the second voltmeter/USB would go in my switch panel:
Upload 2020 1 27 14 14 0
du870
6
7
TN
I mounted mine in the glove box on the side just in case that my rocker switch quits working.
wolf359
wolf359
64
403
Appalachia
I found a spot under the hood that I liked..........
IMG 20200127 162840
BBLASER
159
277
Phoenix
I put mine on the little plastic valence below the front bumper. I figured If I needed to winch and see what I was doing it would be nice to be within sight of it. Looks clean and really isn't noticeable.
Vikes79
Vikes79
SKOL!
11,208
108,920
South Dakota
  2. Talon X4 LV
I mine is mounted in a similar location.
I connect my remote and use my left hand to run the winch for plowing snow while using my right to drive / steer.
much faster than using dash switch only.
JenElio
JenElio
66,664
621,690
Loxahatchee, florida
Pics?🤔
BBLASER
159
277
Phoenix
Winch port
mjleblanc
31
76
Camas, WA
That is an idea, however everyone asks if mine is electric, due to this......
It is the plug port for my onboard dual battery charger. But I might just add the winch port there as well.
20190930 140037
HappyCamper
59
103
Wyo
I mounted mine right in the middle of that little "glove holder" in the lower middle of the dash. I thought about under hood but just didn't want to remove the hood and mess with it while winching and digging and all when stuck.
