Winch installation?
pilsbury38
pilsbury38
47
Is it possible for a guy that's not that great at electrical projects to install his own winch? Lol I been thinking about giving it a shot but still on the fence. It seems it would be much cheaper but not sure I would even know where to start. Opinions please, thanks.....
63,560
Yes. Its easy to wire it using the parts and wire that most winches come with. Even someone who has never wired can do the basic install.
Do you have a mount in mind?
We can help guide you through it.
pilsbury38
pilsbury38
47
Is there a mount you guys recommend? I've seen some kfi combos that have 4500lb winch and mount. Are they any good? I also plan to put a plow on later so is there a certain mount I need? Thanks for the help
KFI SE45 and KFI mount are great for me, no flex ... strong winch. I use a snatch block makes it a lot easier on the winch and battery.
66,384
Cycle country has a mount that is real easy to install and works better with front mount plows I got the KFI mount and it works but in hind site I would of went with the cc one.
justbarriault
10
I used a KFI winch mount and Warn winch. Works good!
zrxrob
zrxrob
41
5
Just put the kfi mount and winch on mine.Very easy took maybe an hour and that's with my ocd with wire routing
D160fcfd4926de66275d9a5fe9914a1d
pilsbury38
pilsbury38
47
Ok, I have the cycle country winch mount and a 4000lb warn winch that I'm gonna attempt to install this weekend. I've been planning on getting a cycle country plow but now I been looking at the eagle plows. Anyone know if the cycle country winch mount will work with the eagle plows?
63,560
Not sure, Most tend to stick with the same manufacture to make sure it works.
Hate to get it and it not fit.
pilsbury38
pilsbury38
47
Has anyone used the cycle country winch mount with a warn winch? If so did you have to drill new holes to mount the winch to the mount?
63,560
Yes. The cycle country winch mount has the standard winch holes found on warn winches.
pilsbury38
pilsbury38
47
Cycle country does not line up with warn, I had to redrill them
63,560
I was looking at there winch mount guide. I see there are two different size of warn patterns. So, depending on the winch I guess it could and could not.
Wonder why they just didn't pre-drill the standard universal layout?
pilsbury38
pilsbury38
47
Nope not mounted, the cycle country bracket won't work with the warn 4000 vantage at all. Winch doesn't hang low enough to put the ears of the bracket over the bumper. Guess I'll be needing a new mount.....
pilsbury38
pilsbury38
47
Kfi has the 4000lb warn vantage listed . So guess it will be a few more days before I get it hooked up.
pilsbury38
pilsbury38
47
New mount should be here Friday, this time I made sure to order the right one! Lol also ordered a 66" eagle plow assembly. With my mechanical skills I should have everything hooked up and working by spring! Lol
