Winch Instruction Tip and Error
Talonpalooza
Talonpalooza
122
237
As it relates to the Contactor, the instructions tell you to connect the RED and BLACK wires first and later it tells you to connect the YELLOW AND BLUE winch wires. Put the Winch Yellow and Blue on FIRST on the contactor. If you put the RED and BLACK on first (Top) you will struggle to access the YELLOW and BLUE terminals underneath the Red and Black on contactor.
Also, at end of instructions Honda tells you to get the BLACK power wire that has blue tape behind the Relay in battery box. The wire is RED not Black...
Reactions: BWAF
63,990
The instructions tell you to connect the RED and BLACK wires first and later it tells you to connect the YELLOW AND BLUE winch wires. Put the Winch Yellow and Blue on FIRST on the contactor. If you put the RED and BLACK on first (Top) you will struggle to access the YELLOW and BLUE terminals underneath the Red and Black on contactor.
Must be why it took so long to get the instructions. The guy is color blind.
