P1000 Wind from shifter
CopenHagen
CopenHagen
34
62
Southeastern Illinois
Got my soft doors on today and now all u feel is a pretty significant breeze coming from shifter holes! Got a idea but don't know how to put it in place .I thought about cutting a normal broom head in half facing the two bottoms towards eachother so shifter can slip in-between them easily and some how fastening them behind dash .thinking this may be enough to slow wind down through shifter gap .any good ideas on this
Reactions: Isaiah
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
Nope, I'm in Tennessee so I'm not going to have that many days to worry about that, but I can see where you could use a solution. Maybe someone will chime in because I don't have any idea that would work very well
Reactions: Isaiah
ghost
ghost
993
1,873
BC
I've been planning to do something about that wind too.
Somewhere on here someone described removing the dash - it looked easy. I cant find it now, but thats gotta be the best way to attach something - from the front or from behind the dash.
Beaudu
Minnesota
I noticed hot air coming from the shifter holes right away, with no doors or windsheild/roof. I thought of it as a handy little hand warmer. MN problems :}
O
oldskoolbuckets
42
25
Colorado Springs, CO
Problem is that it will be a hand freezer in the winter. That is not air from engine compartment.
Beajay
Beajay
41
174
Illinois
Here is what I did
Hawk53
Hawk53
465
591
Alberta Canada
I used a 8" by 8" piece of foam about 3" deep. Worked it in through the slot and then cut it with an olfa knife. Used a little silicone grease in the slot to ease the shifter movement.Had it in place for a few months now . Works good.
IMG 3037
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
That's a good idea too. So what, the whole piece of foam moves with the shift lever or you cut the foam in the shift pattern?
Hawk53
Hawk53
465
591
Alberta Canada
I made a slice from the park position over to the main gate and then straight down to the bottom.
Hawk53
Hawk53
465
591
Alberta Canada
Take the shifter knob off .Move the lever to neutral position or in that area. Size up the foam and make a slice to slide the foam over the shift lever. Slice the rest after foam is in position. Well that's the way I did it anyway.
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
Sweet. I'll have to try that one
Beajay
Beajay
41
174
Illinois
I like it! Gives it a clean look. Does the shifter slide along the rubber easily or does it give some resistance.
It slides easy going to get a better piece of rubber that one was pretty old and a little dry rotted but it works great
Reactions: GlockMeister
Manwell
Manwell
803
2,439
The foam solution looks like a great idea... I'm going to do the same!
Reactions: strongbuilt
CopenHagen
CopenHagen
34
62
How do u take shifter off does it thread on tried taking it off by unscrewing and it was pretty tight afraid I would break it if it wasn't threaded
Hawk53
Hawk53
465
591
Alberta Canada
It pulls off. I found that a slow steady pull worked the best.
RampageRhino
RampageRhino
99
263
Where did you get your foam from?
Hawk53
Hawk53
465
591
Alberta Canada
I got my foam from some packing for a product I received. I would suggest an upholstry shop. Sorry can not be more help.
