Wipers for SATV glass
F
Firedad
46
103
Reno, NV
  1. Talon X4
I have the SuperATV glass windshield and a manual wiper but I’d like to install powered wipers to both sides, along with the windshield washer kit. Anyone already have experience with this? Looking for advice on install and what motor used. I’m looking at the kemimoto wiper/washer kit and a second wiper with motor for the passenger side
Reactions: Remington and TxDoc
107,347
I Havent added the wiper motor to the windshield but Id be interested to see what you do to make it happen.
I did add a second wiper to passenger side tho. Mine are manual btw. Fyi there is knowone that makes a wiper arm to fit the passenger side the way the SATV windshield driver side is set up. That said, i had to bend the arm of a drivers side to make it work.
Reactions: SuperATV and Scoop
F
Firedad
46
103
Reno, NV
  1. Talon X4
Got a picture? I’ll def do as SATV said and go to a pick n pull for the motor and wiper arm. Then I’ll add the kemimoto washer and I’ll be ready to handle my dusty glass
107,347
Let me look. My rig is at my cabin right now. Ill be there friday fo sho! To get a pic
Reactions: Firedad
107,347
@Firedad zoom in on my orange Talon
IMG 6674
Reactions: trigger
Robobrainiac
Robobrainiac
2,465
8,605
This may help some
F
Firedad
46
103
Reno, NV
  1. Talon X4
IMG 4194
IMG 4193
Well this is it. I went with the Kemimoto wiper and washer kit. The wiper arm was too long so I used the arm that came with the manual wiper and it fits perfectly. Wires look messy but we cleaned em up with wire loom. The reservoir is easy to fill and the nozzles easy to install. The angle of the photo makes them look uneven but they actually look factory. I was in a rush so I used the switch that came with the set but intend to order a rocker for the wiper and washer after my elk hunt. I attached the washer switch to a screw on the left side of my switch panel so I wasn’t putting holes anywhere that I didn’t intend to use long term. The spray heads are strong so I had to play with the angle before I made holes to mount. I’m not sure if these are adjustable but one could always find adjustable ones to upgrade and swap out very easily. The wiper motor doesn’t impair drivers view at all and after taking the pic I adjusted the wiper blade so when I shut it down it’s up and out of view. In hindsight I recommend a different wiper motor because this one doesn’t self park. I just didn’t have time to go to a pick and pull to find one. This will work fine for now and was cheap enough.
Scoop
Scoop
4,241
15,891
  3. Talon R LV
I recently ordered the SATV glass windshield for my '23 Talon 1000R LV. It arrived broken. They shipped another one. I'm going to use the wiper from the first one and add it to the second one so I have two. I know you can order a second one from SATV ... I just don't know if it's the exact same one as the first one or not. THEN I will consider adding a motor and reservoir.
F
Firedad
46
103
Reno, NV
  1. Talon X4
I started with the manual wiper and it works fine but with the motor it’s much better. It’s easy to install and cheap so why not?
Reactions: Scoop and Smitty335
107,347
Looks good. You must be under 6’
Dosent the motor location get in your line of view otherwise?
Im 6’-2” and my eyes are right in that general area or at the bottom of that with my SATV windshield in my Talon. That would drive me nusts
F
Firedad
46
103
Reno, NV
  1. Talon X4
I’m 5’9. It doesn’t bother me at all. It only hangs as low as my rear view mirror. It probably looks lower because I took the picture from above, looking down at it. At your height I couldn’t imagine getting in and out of the seat. I use mine for hunting so I’m stopping often to get out to glass
107,347
I have No Issues getting in or out. Depends how my old baseball knees feel that day tho lol. I also have a Swamp donkey stereo up top to.
U @ 5-9 Yup, that motor aint gonna bother you. But that motor looks like its at rear view mirror hight to me.
So you Use the Talon For hinting? I use my P1k5 for that. How are u getting big game in the back of the rig, haulin a trailer behind it? 😂
Pro tip: just the tip 🤣
Seriously tho, Make sure when u respond to someones post to hit the “reply” button under there post then the box (see above) pops up then type your response under it. That person gets a notification like you just did for this one. I just happened to come back on and came accross your response this morning. Otherwise I would have never known you responded.
Reactions: Scoop
F
Firedad
46
103
Reno, NV
  1. Talon X4
I have room for a deer or an elk in the back because I quarter them. If I’m lucky I’m putting the quarters straight into the machine, otherwise I’m hiking quarters some distance, with help usually
Reactions: Scoop and Remington
107,347
That take alot of work in the field but necessary at times.
Got to look goofy in a talon tho lol
Reactions: Scoop
