Yamaha Wolverine X2
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
Drop the sway bars!
I've had it off the back. Definitely more flex and different ride but then this happened.
IMG 1477
IMG 1479
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
so how is the 700 different than the x2? louder, heat, more leg room, more vibration? what else? @CumminsPusher @Plumber32 @Choogsbro
Reactions: Plumber32
Deleted member 3748
Less power obviously. But R-Spec to R-Spec, the 700 has another inch of suspension travel. The X2 doesn't have the overheat issue, radiator mud guards come from the factory, payload and towing capacity are higher. I'll need the other guys to say if there is anything else.
67,347
No heat what so ever, yes its louder, better suspension. More leg room, wider stance.
Reactions: CumminsPusher
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
Only going on what I've heard. Original is a more comfortable ride and more cab room. X2 is very quiet and has more power. To me I was very disappointed that they didn't put the 850 in the original R-spec. To me that would be the very best trail machine out there. Just my opinion. For the life of me I don't know why they lessened the travel.
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
The other thing that I can't understand is the speed limiter. Out of the box the original has a higher top end. If you buy either I would install a JBS sheave and slug the clutch. I've done it to my Rhino and to my Wolvy. Makes it a totally different machine. Just my opinion.
Deleted member 3748
In my opinion they should of just put the 850 in the existing chassis, but it's got plenty of power.
From the outside they don't even look much different, but everything is different. I would have liked them to keep the original chassis as well. It is exactly the same as the X4 so maybe they needed to make the changes for the extra 2 seats.
Deleted member 3748
The Weller ECU flash does away with the limiter.
