Fresh rebuild on 09 BR 700, new oil, cjecked oil level. Runs great, goes to shift into second and looses power and feels like it had an engine brake. No shift what so ever??? Whats am i missing....
2012 big red of mine did o rings new oil pump new toqure converter still didnt move heard it clunk in gear so pulled motor split case an there i found screen sucked up fast with sludge from clutches ordered new parts put back together works awesome hope this helps
Did your install or check your camshaft? A bad camshaft caused mine to not shift into second gear unless throttle was reduced slightly when speed was appx 15mph.
