Brand new when I got it for my 2014 CB1100 deluxe. View attachment 30174
I was pleased.. you?Got my new manual.
Yes mine is in the shop for the same thing just shuts off, won't start unless u turn the key off then turn it back on and it starts right back up, you can drive it 5 feet or Mile before it does it again, just wandered if u got yours fixedany of you guys had this happen? it was running fine then just shut off. after it sits for a few minutes it will start up and go about 50' and shut off again. the engine light blinks 1 long 3 short blinks so im sure that means something. any help is appericeated since hunting season is over next weekend! couldn't have happened at a more inconvenient time of course
This forum is awesome! My Honda Pioneer 700 kept shutting off intermittently. I took it to the dealer and couldn't find anything defective. They gave it back to me and it started shutting off again. I checked the ground on the passenger side as recommended by this post. Sure enough the wires behind the bolt was loose. I tighted it up and it seems to be fixed!There's 3 separate grounds that need to have good connection. In the manual it shows where they are located. Probably a good start. I believe the manual also talks about what the various blinks mean.
