1000 LE worth the extra money?
marksmac3
truckee CA
I am wondering whether folks think that the I-4wd and fox shocks are worth the extra cash over just buying a 1000 Deluxe and buying the same shocks to put in myself?
Reactions: Isaiah
BigOL3
BigOL3
2,994
8,920
The Fox shock and other accessories are good, but the deciding factor against and LE is I did NOT want the I4wd. I much preferred the lock front Diff, so I stayed with the Deluxe.
273,461
I've had a 2016 P1K5 Deluxe with over 3k miles and now a 2018 P1K5 LE with over 4k miles on it.
I have been very satisfied with the I-4WD system, no issues at all. Some shy away due to the added cost, complexity, and potential for issues due to the added technology to make I-4WD work and they want the security of being able to manually select a fully locked front differential.
If you dont intend to run extreme difficult terrain the I-4WD does offer the advantage of set it and forget it driving experience by turning easier and tighter than the Deluxe version in 4WD and 4WD Lock while kicking in when needed.
All depends on personal preference, I love the added internal storage, front bumper and Fox Shocks which all 3 can be had for about $2k vs. a $4k difference between Deluxe and LE MSRP.
It all boils down to if painted plastic and I-4WD is worth another $1500 over the aforementioned options.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
This sums it up pretty well.
Reactions: JACKAL and Isaiah
rickoshea
deluxe gives you the choice of 4wd or 4 lock.i use 4wd for muddy, long ruts where i don't want to fight the steering.5k more for shocks and a front bumper,and other stuff i have no use for?pass.i did purchase Elka stage 3 shocks though,which according to my research are superior to Fox qs3's.
Reactions: Isaiah
