P1000 172-DEGREE WINDSHIELD WIPER KIT
GROR
GROR
74
275
53
Castle Dale, Utah
ghostrocksoffroad.com
FITS: 2016-2025 HONDA PIONEER 1000 SXS M3/M5/M6 WITH INSTALLED HONDA GLASS WINDSHIELD - P/N 0SU85-HL4-A00.
  • The wiring harnesses and switches provided connect to a dual battery auxiliary fuse box; no other OEM wiring components or harnesses are required for installation.
  • Kit Features a 172-degree 2-speed large sweep electric Wiper motor with Dynamic Park Function.
  • Plug-and-Play Wiring Harnesses are designed for easy installation and include high-quality Carling switches for durability and reliability. They connect seamlessly to your existing aftermarket auxiliary fuse box.
  • 14” - 18” adjustable Radial Arm, J-hook blade connection. With 14”/350mm J-hook wiper blade and wet kit
  • A one-gallon Washer Tank Reservoir mounted under the driver's seat provides ample washer fluid capacity for off-road adventures in any condition
    Note: The innovative tank bracket design allows you to store essential items such as toe straps or tire repair kits while maintaining the critical functionality of the storage area.
    The Complete Kit Contains:
    172° Sweep, 2-Speed Motor
    • Plug-and-Play Wiring Harness Components
    • Wiper Arm and Blade
    • Washer Reservoir and Mounting Bracket
    • Tubing and Spray Nozzles
    • All Necessary Hardware for Installation
Avalible at www.ghostrocksoffroad.com
20241013 142427
Bracket install
Pro ugvYrcfl
20241013 161250
Pro fkldLepw
Wiper master kit ghost rocks off road
283,191
View attachment 452717View attachment 452718
@GROR with this particular motor, have you looked at possible fitment with any of the glass windshields for the Talons? I'm running the SupertATV glass windshield with the offset manual wiper. If it would clear the ROPS on the inside I don't mind drilling a hole in the center to accommodate the wiper motor shaft. Just eyeballing it doesn't look like much interior space in the center where windshield meet up and mount across the top.
283,191
I have not tried any other windows. It is the same motor that polaris uses. I have a motor that we used used for mock up. I can send it to you and let you try it
Thanks for the offer, I was curious if it had been tried with the Talon. Still on the fence of going or trying that route.
Reactions: Remington and ChadD
283,191
I looked at the Honda OEM wiper, and it looks different than our setup.
Thank you for doing a comparison, I suspect it's a special OEM spec unit for Honda, should be for $800+ it better wipe more than the windshield LOL
NorthernJoe
NorthernJoe
386
1,491
Northern Ontario
Hey @GROR Do you have a motor only option for us poor guys that bought the OEM Honda wiper kit that only clears 1/2 the windshield ?
Reactions: All5Hondas
283,191
Reactions: 906UP
nitrotmann
nitrotmann
80
224
  1. 1000 6 Crew
Any chance you supply the wiper kit for Troy alumilite in parowan?
Sent from my SM-S908U using Tapatalk
GROR
GROR
74
275
53
Castle Dale, Utah
Here are some photos from our installation instructions. The motor is a two-speed dynamically parked motor when switched off from any position on the sweep it parks. The Motor is very powerful and designed for a 24'' arm and 24'' wiper blade.
The washer setup uses a custom-built bracket that fits under the seat and holds a gallon of fluid. There is also room for tow straps and other rigging equipment or tools. I keep mine in a dry bag.
Everything is included with the Kit, including wire harnesses for the motor and tank, and we only use genuine carling switches. The wire harnesses are wired up to any auxiliary fuse box with a 20 amp fuse.
If you have any questions, please don't hesitate to let me know.
[email protected]
Wiper arm 6
Wiper arm 3
Wiper arm 2
Wiper arm 1
Pro XzlVrRBx
Wire hrness wash Tank
20240806 140217
20240808 085438
20241013 142427
