Multi 2017 Pioneer Takeover - April 28 & 29th - Ride Royal Blue!
Tramguage1
Tramguage1
Texan
7,587
31,351
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I know and I don't blame ya! Nothing starts a trip out worse than equipment issues on the way!
If i dont remove and repack the bearings i would ne double checking every stop! Just a tip! I carry a HF thermometer gun with me to check for hot berings every stop.
70,198
I just had mine all redone. Bearings, tires replaced one tweaked axel . It was new to me and dont believe it was touched since it was new in 08. And 6yrs is life for trailer tires
Tramguage1
Tramguage1
Texan
7,587
31,351
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I learned the hard way, I only use trailer service tires and replace after 5 years nomater how many miles. I had to leave my tracktor and my wife on the side of the road after blowing 2 tires and that was after installing the spare in the restaurant parking lot. 3 tires within about an hour.
I'd be over anxious checking things after that nightmare
70,198
Which one were you more worried about getting stolen?
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
Tramguage1 I had something similar happen to me back in 2000 with a 2 horse trailer going from Mississippi to New Mexico. Hate it when It happens. :mad:
Reactions: Tramguage1
70,198
Ive read its a good idea to air down before you cross hot areas like az. Or desert country because the tires heat way up and blow from pressure.
Reactions: moparornocar
Dp5hunter
Dp5hunter
3,056
My problem was that in Mississippi I am at 500 ft above sea level and in New Mexico I was at 5000ft so the higher u go the lesser air pressure in the atmosphere so the air in my tiers expanded and busted my tiers. When I checked the tier pressure after my second blowout my tires where at 75psi when I left Mississippi they were et 40psi.:confused:o_O
Reactions: JTW and Plumber32
Tramguage1
Tramguage1
Texan
7,587
31,351
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
A week before the Takeover last year, i had to replace all four tires on my GMC 2500 and my trailer. Im starting to see a pattern!
Reactions: Dp5hunter and JTW
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
But airing down causes more heat from increased rolling resistance. Catch 22. I'd rather run proper inflation and the tire run cooler to begin with.
CPope
CPope
352
1,152
Pulaski TN
Try nitrogen, I had several blowouts on our fifth wheels, changed to nitrogen a few years back and seems better. I also now use a TPS, this alone has saved a blow out because it alerts when pressure increase or decreases or temperature rise. Being able to monitor while cruising is a comforting feeling.
nbomar
nbomar
4,416
17,855
Springdale, AR
I use the tst tpms system on my dually and my camper. Gives me pressures and temps of all tires.
