2020 Tallon X4 shifting hard and stalls
5,744
26,370
Well, I learned that US-127 Powersports isn’t the best place to take your machine to be fixed. As I stated in the past post the said that it was low on oil and that why it was shifting bad and stalling. “I kind of wanted to call bulls*** because I checked the oil during all of my trouble shooting that I could think might be the issue”. With that being said I had to go with what they told me and take it for a test run. As always it ran fine until about halfway through the second day and it was right back to the same issues. I have some spare time coming up so I think I’m going to try to dig into it myself. Is it a big job the change the clutches if I replace the cylonoide and that’s not the problem? Thanks in advance for any help.
Solenoid isn't a horrible job, buy the new gasket for the case, and have some fresh RTV/Silicon to seal the wiring pass thru.
Clutch is a little more involved, but is pretty easy if you take your time.
I think @CumminsPusher did a detailed clutch replacement thread. It was on a Pioneer 1000 but they're virtually the same.
5,744
26,370
Might be easier and even more room on a talon.
You're right, I watched those guys do a campsite oil change and was surprised at how difficult it was to access the two oil filters. :oops: Everything is pretty much right out in the open on a Talon.
DRZRon1
DRZRon1
1,434
4,391
PA
hi - so did they get it to take a relearn?
Hello_Darkness
Hello_Darkness
665
2,672
Just to the right of nowhere
In my experience the solenoid needs replaced due to contamination, so I would clean out everything I could touch before installing a new 1. Same way with a clutch replacement. The whole system should be cleaned out.
Reactions: Remington and CID
E
Evradley76
10
20
  1. Talon X4 LV
I want to thank everyone how gave me information on fixing my issue. It ended up being either the linear cylinder or one of the 3 shift cylonoids. I replaced them all and this issue is fixed. Thanks again!!
