![Alaska350](/data/avatars/m/34/34294.jpg?1646835405)
So I recently added 1.5” super Atv a-arms to the front so I could run my bigger tires but now I feel my back bottoms out here and there thanks to the bigger tires. I plan in installing the rear a-arms this weekend to help give the rear a little more room but with the normal weight I run in the back (canopy and dogs) I am thinking a small lift or new springs would help. I already adjusted the back shocks 2 clicks and it bottoms out less but still happens on rough fast bumps.
I have read that a 2-3” lift will require new axles if I have the arched forward a-arms installed but I want to avoid that if I can. Does anyone know if there is a 1” lift spacer kit available or heavy duty springs that will work but allow me to keep the stock axles?
