P1000 2021 Pioneer 1000-5 overheating
cdoerhoff
cdoerhoff
23
55
St Louis
My sxs overheated 2 weeks ago and then today. We were on the trails both times. Today the radiator fins were dusty at the bottom. The reservoir is completely full when I checked it after my warning light came on. It's still under warranty. I'm always afraid the dealer is going to tell me its my fault. Any suggestions what to ask, what to look for? It only has 600'ish miles.
107,220
wash you radiator. I bet you have trail gunk in it your not seeing
Plowboy1466
Plowboy1466
290
1,453
Ashland, Ohio
Burp your cooling system. I bet you've got an air pocket in there. Plenty of topics about this. And P1K5Dave is also correct, if air can't flow through the radiator it can't cool the antifreeze.
cdoerhoff
cdoerhoff
23
55
St Louis
Have you been able to verify that your fan is kicking on?
Yes. Sort of. Technically, I can confirm it comes on after I've restarted the rig during the overheating but not while up to the process of overheating. I'll verify that in the morning.
P1K5Dave
P1K5Dave
2,180
8,161
Petoskey, MI
If you've seen it running at all, we can scratch a faulty connection from the list. The only other question would be whether the thermostat is telling it to run or not, and that's kind of far down the list.
Burping is probably your solution, provided your radiator isn't full of mud. Do you have a service manual? It's a pretty easy job
cdoerhoff
cdoerhoff
23
55
St Louis
I have the service manual and I'm all about youtube. The first time it overheated, I had a the coolant boiling and coming out the top. I never thought about an air pocket in the line. I'll let everyone know how it goes. I was driving it around today with no issues.
DRZRon1
DRZRon1
864
2,800
probably air, but is the radiator really clean, it is amazing how much dust\mud they can hold. I carry a 1 gallon pump sprayers to clean on the trail, don't leave home without it. a garden hose will do the job :) .
Reactions: Lady01 and ChadD
P1K5Dave
P1K5Dave
2,180
8,161
Petoskey, MI
I've never cleaned my radiator, and I'm always at 2 bars.. I guess it just depends on your environment.
