P1000 2022 Honda Pioneer 1000 Accessories Listing!
67,178
5
6
7
9
10
67,178
Text listing for searchability.
ROOFS • TOPS • REAR PANELS​
Bimini Top (Black) 0SR85-HL4-322A $197.95 • • • • Not compatible with Honda Fabric Doors, Hard
Bimini Top (Black) 0SR85-HL4-322B $129.95 • • • • Doors and Windscreen/Windshield Accessories.
Fabric Roof/Rear Panel (Black) 0SR85-HL4-211A $259.95 • • • • Full Poly Windscreen or 2-Piece Poly Windscreen
Fabric Roof/Rear Panel (Black) 0SR85-HL4-222A $359.95 • • • • (either Hard Coat or Optical) required for installation.
Fabric Roof/Rear Panel (Camo) 0SR85-HL4-220A $299.95 • • • • Full Poly Windscreen or 2-Piece Poly Windscreen
Fabric Roof/Rear Panel (Camo) 0SR85-HL4-221C $399.95 • • • • Applies to 2020 and prior model years with Camo.
Hard Roof 0SR85-HL4-A50 $826.95 • • • • Roof adds approximately 3" to the height of
Hard Roof (Gray/Black) 0SR85-HL4-G50 $947.95 • • • • the vehicle.
Hard Roof 0SR85-HL4-A30 $557.95 • • • • Roof adds approximately 3-3/4" to the height of
Hard Roof (Gray/Black) 0SR85-HL4-G30 $639.95 • • • • the vehicle.
ELECTRICAL​
Audio System & 2 Front Speakers 0SS22-HL4-A00 $744.95 • • • • • • • • Requires Accessory Fuse Box, Fuse Box Wiring Kit, and
Fuse Box & Audio Mount Bracket.
Powered Subwoofer 0SS22-HL4-A50 $679.95 • • • • • • • • Requires Accessory Audio System, Fuse Box, Fuse Box &
Audio Mount Bracket and Fuse Box Wiring Kit.
Rear Speaker Pods (2) 0SS22-HL4-A40 $349.95 • • • • • • • • Requires Accessory Rear Speaker Mount Kit.
Rear Speaker Mount Kit 0SS23-HL4-A00 $99.95 • • • • • • • • Required for Rear Speaker Pods.
Fuse Box 0SS25-HL4-A00 $210.95 • • • • • • • • Requires Accessory Fuse Box Wiring Kit, and Fuse Box &
Fuse Box/Audio Mount Bracket 0SS27-HL4-A00 $54.95 • • • • • • • •
Fuse Box Wiring Kit 0SS26-HL4-A00 $82.95 • • • • • • • • Requires Accessory Fuse Box and Fuse Box & Audio
Mount Bracket.
Garmin Tread Powersport
Navigator 0SS50-HL4-A00 $749.95 • • • • • • • • Requires GPS Wire Harness.
GPS Wire Harness 0SS51-HL4-A00 $22.95 • • • • • • • •
Heater 0SE08-HL4-A00 $999.95 • • • • • • • • Requires Accessory Fuse Box, Fuse Box Wiring Kit, and
LED Auxiliary Lights 0SV31-HL3-201 $319.95 • • • • • • • •
LED Headlights 08V70-HL4-AK0 $399.95 • • • • • • • • Requires Accessory LED Headlight Wire Harness.
LED Headlight Wire Harness 08V70-HL4-AQ0 $25.95 • • • •
LED Headlight Wire Harness 33130-HL4-A10 $18.77 • • • •
20" LED Light Bar 0SV31-HL4-A00 $381.95 • • • • • • • •
Confirm additional required Honda parts necessary to
complete installation — depending on Pioneer year/model
application.
LED Light Bar Wire Harness 0SV31-HL4-301 $49.95 • • • • • • • •
45mm Light Clamp 0SV31-HL4-201A $29.95 • • • • • • • • For installation of LED Auxiliary Lights and LED Light Bar.
Back Up Alarm 08V70-HL5-A00 $39.95 • • • • • • • • Back Up Alarm Mount required for installation.
Back Up Alarm Mount 08Z76-HL4-A00 $29.95 • • • • • • • • Required for installation of Back Up Alarm.
Horn Kit 08P75-HL5-A00 $34.95 • • • • • • • • Horn Kit Wire Harness required for installation.
Horn Kit Wire Harness 08Z77-HL4-A00 $59.95 • • • • • • • • Required for installation of Horn Kit.
REAR PANELS​
Fabric Mid-Panel 0SR95-HL4-211A $148.95 • • • •
Must be used with Windscreens or Windshields and Hard
Fabric Rear Panel 0SR95-HL4-206B $148.95 • • • • or Fabric Roofs. Not compatible with Rear Fabric Doors.
Fabric Rear Panel 0SR95-HL4-211B $139.95 • • • •
Hard Rear Panel 0SU95-HL4-A30 $725.95 • • • •
Hard roof required for installation.
Hard Rear Panel (Gray/Black) 0SU95-HL4-G30 $783.95 • • • •
Hard Mid/Rear Panel 0SU95-HL4-A50 $682.95 • • • •
Hard Mid/Rear Panel (Gray/Black) 0SU95-HL4-G50 $736.95 • • • •
WINCH • PLOW • TOWING​
Winch 08L71-HL3-A43 $484.95 • • • • Requires Winch Mount Kit.
Winch Mount Kit 08L72-HL4-AK1 $369.95 • • • • Required for installation of Winch.
Plow Blade 72" 0SL76-HL4-A00 $598.95 • • • • • • • • Plow Push Tube, Plow Mount Kit, Plow Blade and Plow
lifting device required for installation. Pioneer 1000 3P also
requires Plow Pulley Kit.
Plow Mount Kit 0SL73-HL4-A00 $267.95 • • • • • • • •
Plow Push Tube 0SL70-HL4-A00 $571.95 • • • • • • • •
Plow Pulley Kit 08L77-HL4-A01 $61.95 • • • • Required for installation of Plow for 3P models.
Receiver Hitch Plug 08L76-HL4-A00 $14.95 • • • • • • • •
Draw Bar 08L90-HL1-100A $44.95 • • • • • • • • Allows installation of 1-7/8" or 2" hitch ball.
Hitch Ball 08L90-HL1-100C $14.95 • • • • • • • • 1-7/8" hitch ball – includes nut and lock washer.
WINDSCREENS • WINDSHIELD​
Full Poly Windscreen (Hard Coat) 0SR72-HL4-A20 $665.95 • • • • • • • • Utilizes Honda Tool-Less clamp system.
Full Poly Windscreen (Optical) 0SR72-HL4-A10 $533.95 • • • • • • • •
Glass Windshield 0SU85-HL4-A00 $1,043.95 • • • • • • • • Utilizes Honda Tool-Less clamp system. Not compatible
with Fabric Roofs.
2-Piece Poly Windscreen (Hard Coat) 0SR71-HL4-A20 $761.95 • • • • • • • •
2-Piece Poly Windscreen (Optical) 0SR71-HL4-A10 $602.95 • • • • • • • • Utilizes Honda Tool-Less clamp system.
Wind Deflector 0SR73-HL4-A00 $227.95 • • • • • • • •
Windshield Wiper Kit w/ Washer 0SE10-HL4-A00 $516.95 • • • • • • • •
Requires Accessory Glass Windshield, Fuse Box, Fuse
Box & Audio Mount Bracket and Fuse Box Wiring Kit. Not
compatible with Underseat Storage or Subwoofer.
DOORS​
Fabric Front Doors (Black)) 0SR90-HL4-212A $626.95 • • • • • • • •
Fabric Rear Doors (Black) 0SR90-HL4-212B $610.95 • • • • Not compatible with Hard Mid Rear Panels and Fabric Cab
Rear Panels.
Fabric Front Doors (Camo) 0SR90-HL4-232C $699.95 • • Honda Phantom Camo 2.0 applies to 2021 and up.
Fabric Rear Doors (Camo) 0SR90-HL4-252C $649.95 • Honda Phantom Camo 2.0 applies to 2021 and up.
Hard Front Doors (Gray/Black) 0SU95-HL4-GD0 $3,667.95 • • • • • • • • Accepts Side Mirrors.
Side Mirrors 0SV05-HL4-202 $159.95 • • • • • • • •
Mirrors attach with Quick-Release clamps when using
Hard Doors. Do not apply with Fabric Front Doors
and Glass Windshield.
PROTECTION​
Aluminum A-Arm Guards (Front) 08P70-HL4-AK0 $217.95 • • • • • • • •
Aluminum A-Arm Guards (Rear) 08P73-HL4-F00 $225.95 • • • • • • • •
HMW A-Arm Guards (Rear) 0SP75-HL4-100 $199.95 • • • • • • • • Ultra-rugged, extremely durable HMWPE (high
molecular weight polyethylene.)
Aluminum Skid Plates 08P73-HL4-AK0 $520.95 • • • • • • • •
Front Bumper/Brush Guard 08P71-HL4-AK0 $434.95 • • • • • •
Front Fender Flares 08F70-HL4-AK0 $156.95 • • • • • • • •
Rear Bumper 3P 08P70-HL4-AN0 $227.95 • • • •
Rear Bumper 5P 08P72-HL4-AK0 $231.95 • • • •
Front Seat Covers (Camo) 0SP32-HL4-A30C $189.95 • • Honda Phantom Camo 2.0 applies to 2021 and up.
Rear Seat Covers (Camo) 0SP32-HL3-A40C $139.95 • Honda Phantom Camo 2.0 applies to 2021 and up.
Rubber Floor Mats 0SP63-HL4-102 $149.95 • • • • • • • •
Storage Cover 0SP34-HL4-100 $179.95 • • • •
Fits with or without Honda Accessories.
Storage Cover 0SP35-HL4-100 $148.95 • • • •
CARGO​
Bed Extender 08L71-HL4-A02 $319.95 • • • •
Bed Liner (CA Only) 0SP43-HL4-203CA $378.95 • • • •
Bed Liner (Non CA) 0SP43-HL4-203 $378.95 • • • •
Bed Mat 3P 0SP42-HL4-202 $194.95 • • • •
Bed Mat 5P 0SP42-HL4-502 $160.95 • • • • Rear seats cannot be used when Bed Mat is installed.
Cab Frame Cargo Bag 0SL57-HL3-101 $69.95 • • • • • • • •
Dash Pocket Net 0SL60-HL4-A00 $27.95 • • • • • • • •
Under Dash Storage Pocket 08L71-HL4-F00 $124.95 • •
Under Seat Storage 08L71-HL4-AK0 $129.95 • • Not compatible with Powered Subwoofer or
Windshield Wiper Washer Kit.
MISCELLANEOUS​
Flag with mount 0SR95-HL4-F10 $57.95 • • • • • • • •
Fox Front Shocks 08Z70-HL4-F00 $849.95 • • • 49 State, non-California Models. Requires Fox Rear Shocks.
Fox Front Shocks 08Z70-HL4-F50 $849.95 • • • 49 State, non-California Models. Requires Fox Rear Shocks.
Fox Rear Shocks 08Z71-HL4-F00 $879.95 • • • 49 State, non-California Models. Requires Fox Front Shocks.
Fox Rear Shocks 08Z71-HL4-F50 $879.95 • • • 49 State, non-California Models. Requires Fox Front Shocks.
Rearview Mirror NEW 0SV05-HL4-300 $99.95 • • • • • •
Elvis8310
Elvis8310
54
103
Edmond, Oklahoma
Will any of the stereo stuff work in a 2021 deluxe? Also looking for glass windshield with washer kit.
Also looking for full fox setup for my 2021 1000-5 deluxe.
