2022 pioneer 1000
JenElio
JenElio
73,395
667,631
Loxahatchee, florida
Also another question since you’ve got a much better understanding of the machine than I do, with the satv 3” lift still work with this machine ? They say on the website it works for the 22’s
This is the man to ask 👉 @SuperATV. 👍
Little bit of a weird guy but I'm sure he can answer your questions.....😂😂😂
JenElio
JenElio
73,395
667,631
@Gsik12 I don't see where SATV says their arms fit the 22s. The site says 16-21.
It's probably going to be a bit for these guys to get another design into manufacture.
His a-arms are from C-fab. The 3" lift is from SATV. Which I believe is a bracket lift?? So may work 🤷‍♂️
Russ989
Russ989
22,642
147,257
You guys are forgetting this is a 2022 the out put high range gear in the sub transmission is 47 tooth instead 49 like the 2021 thru 2016's so first through fifth gear is lower, sixth is higher it will be tuff to pull sixth gear with 32's but first thru fifth will feel like it's on 30's.
That will help but I still think it’s a load for a pioneer. How may HP did it go up?
115,787
My answer will be biased cuz don't like bracket lifts for a multitude of reasons.
The person to answer that question is @SuperATV
He'll see this and will b on later
Gsik12
Gsik12
Manitoba
Time for powder coat ? Or leave as is?
00AA7419 9218 4B73 BAA8 7934A608C89D
SuperATV
SuperATV
1,364
9,521
Madison, IN
www.superatv.com
Hey!
Sorry I'm late. Online traffic is backed up for miles!
C8acf8c136d5a7020b8fb9abdb58a096
SuperATV
SuperATV
1,364
9,521
Madison, IN
www.superatv.com
@Gsik12
We don't have a 22 in here yet. It was supposed to be here last Friday....but took a wrong turn somewhere. Hopefully we'll see it before the weekend.
A-arms.... Going to need an all new design for the 2022.
Lift Kit: Can't confirm just yet. Its possible...and the bracket lift would likely bolt up, but I can't say that its going to play well with any suspension changes on the 2022 yet. We'll have to try it out first.
I'm betting portals will bolt right up. Doubt they'd change the hubs...but its possible the hubs could have changed if they changed the ball joints when they updated the A-arms.
Going to need a specific 2022 Frame Stiffener....and likely a new front piece for a skid plate.
I'll post up as soon as it gets in and I get to look it over.
Gsik12
Gsik12
Manitoba
@Gsik12
Sounds good thanks for the reply, I’m hoping it fits. When I ordered the lift it said it fits a 16-22.. fingers crossed
4AA4B8D6 F36E 4BD8 A42B 189B2C0F8CF1
272,186
No way 16-22 model year is accurate. Only 16-21.
A man buys 30 -32 tires. $1100
A man then buys 1.2-2" forward A arms to accommodate tire diameter. $600-$900
A man finds out the 32" still rub add lift kit $200
A man then find out steering rack doesn't handle that heavy tire combo on front. Better Steering rack $600
Machine now feels like a sluggish P700 with clogged air filter. Goes with gear reduction or Portals reduction $500-$3000
Sure is a lot of money for cool looking big tires when 28" will go 99% of the same places for $5000 less. I think those people should start squatting thier Pioneer so we can spot them far off.
TripleB
TripleB
15,264
136,419
Caryville, Tennessee
A man then find out steering rack doesn't hankie that heavy to combo on front. Better Steering rack $600
Sure is a lot of money for cool looking big tires when 28" will go 99% of the same places for $5000 less. I think people should start squatting thier Pioneer so we can spot them far off.
I think the steering rack is $750 now.
