2023 Talon 1000R stock wheel offset and backspace
JohhnyM
Granby, CO
  1. Talon R LV
Hello All, I recently purchased a Honda Talon 1000R that has stock tires and wheels. I have also recently purchased a set of M1 Evil tires in size 32 10-15.
My question is this, does anyone know what size the stock wheels are ? I know they are 15", but don't know the width. I'm contemplating on putting the Evils on the stock wheels but would like to know what wheels would be a replacement, should I decide to go with new wheels.
Thank all for your time, John
5,736
26,291
Welcome from the once great state of Colorado. :cool:
I can't be specific but the stock front rims are about an inch narrower than the rears. Many have put 32's on the stock rims.
There are two choices for aftermarket wheels - 1. Stock offsets, front and rear; 6+1 fronts, 4+3 rears, you can't rotate. 2. 6+1 all the way around with 1-1/2" spacers on the rear to 'square' you up, front to rear. The Talon's front track is 3" narrower than the rear.
There's a third choice but less popular - 6+1 all the way around without spacers. The rear will have a 3" narrower track width but will probably turn in quicker. It'll be hardly noticeable, either visibly or handling wise.
280,891
Front wheels are 6.5x15 with a 30mm offset
Rear wheels are 8x15 with a 50mm offset.
Bolt pattern 4x136mm.
