Update mostly resolved due to loose connection.
So shortly after purchasing my 2024 Pioneer 1000-5 Deluxe I replaced the OEM headlights with full replacement plug and play LED lights with integrated DRL & Turn Signals, everything worked as it should at first. After about 60 days the DRL then intermittent Hi Lo beams would stop working one side to the other. Finally both headlights stopped working completely Hi, Lo, DRL, Turn Signals, all dead. Tail lights and brake lights work fine still.
I have the Turn Pro plug and play Turn Signals installed and the turn indicators with it work on all 4 corners as they should.
So today I removed the aftermarket Chinabomb LED lights, replaced the full OEM halogen bulbs and have a set of LED bulbs. My issue is I still have no headlights whatsoever. I have checked the following:
Headlight fuse in fuse block - OK
Main Headlight relay - clicks on with ignition and reads 12V. Also continuity withall 3 relay socket ground terminals as appropriate.
Lo Beam Relay - clicks on/off with Lo headlight switch and reads 12V.
Hi Beam Relay - clicks on/off with headlight switch on Hi switch and reads 12V
Not sure what else could be stopping power through OEM harness from relays to Headlights plugs at sockets.
Any suggestions, past experiences 🤔
@Hondasxs @Hello_Darkness @lee
Thanks in advance for any input.
