P500 27s on stock wheels
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
@trigger oh yeah spacers are a must for sure. Won’t be any off camber riding until there on that’s for sure common sense when you go up you go out anybody that says difference is crazy.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I imagine this is the case particularly with the stock rims - my ITP wheels have a wider offset than stock, so I run them without spacers and I have no stability issues even in some crazy terrain.
Lilred500
Lilred500
548
1,997
Wv
Yes if I had some offset wheels I wouldn’t worry about it. But here in wv the terrain can get terrible and it needs widened out.
T
Tstover
141
398
Central PA
What's funny is when guys put taller tires with no spacers on stock wheels and tell you it rides great and isn't any tippier. Lol, it's a pucker fest and until you ride one that's truly stable you just don't know any better. ;)
Looking to upgrade to 26’s next year, on stock wheels. What size spacer do you recommend?
T
Tstover
141
398
Central PA
Depends what set up you're planning to go with, 9's and 11's, same size all around? They'll be different sizes if your going for an even track width.
Yep, 9’s and 11’s most likely.
T
Tstover
141
398
Central PA
You could run 1" or 1.5" on all four and have a pretty even track width then. It'll be stable with 1" if you're looking to stay close to 50".
Thank you for the reply. I’m sure this info is out there, but what are you running, tire size and spacers?
Edit: Thanks to all that replied. I’ve only had my P5 for 5 months so I appreciate the input from all the more experienced owners.
196,414
Mine's set up a little different than most. I've ran just about every configuration at one time or another. Right now, 26x11's on 5+2's on all four. 1" spacers on the rear only.
Reactions: Rustneversleeps
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
I'm thinking of 27-10 12 all round on stock wheels with 1.5'' spacers all round but wondering if the 27-10-12 tires will fit the front stock wheels 12 x 6.Do you think i can get away with 4'' wider tire for front...Also wondering to of it would be harder to steer with 10'' wide without power steering..Thank in advance Trig.
196,414
I had 9's on the stock wheels and Belle Tire didn't b**** about mounting them, I would think 10's would work. Don't know what brand you intend to get, some don't run true to size and generally run smaller. I'm sure it'll be a little harder to steer but other guys are doing it, might suck in a real tight spot trying to turn around though.
Splorin
320
904
Maine
Tire companies specs can be vague sometimes. I've used 10" radials on stock 6's on a lot heavier and faster machine and they were only 25's. Keeps my beads out of trouble. Taller would be even better. Had to dial in air pressure at first but they worked great all around either in swamps or 65mph fire road stupidity.
T
Tstover
141
398
Central PA
Thanks Trigger. I saw a post you made on another thread showing your machine and your lights. You’ve spent some time making that rig your own! Enjoyed the music too, Rammstein and ZZ Top can make an angry white man like me happy!
Reactions: trigger and Mudwing
Darin-5280
Darin-5280
9
15
Louisiana
I spent some time reading this forum and finally decided on some 12” ITP Delta Steel Wheels 5+2 with Maxxis Zillas 27x9 on the front and 27x11 on the rear. I was going to buy some spacers at first and use my factory wheels but after I priced the spacer and the installation of the new tire, it was just a little more to buy this setup on eBay delivered with the tires already mounted.
FB219667 F153 4831 895A 137C785DCCE5 A14A5A2A 2366 4239 A3C9 01B3C2CB9CBD 7D3745AF B1A2 40F7 91B3 3BD2A7337CA4 52844F75 5BC9 468D BAFE 781EBAFE89B5 A755BE0B 46C1 4514 8FFC 53C585B66BDE AE966F7D FA31 48CA 9661 3EFC57A6D4CD
futzin
futzin
4,816
35,332
Kentucky
Thanks for the pics. What is the width now? (since you have your tape measure out!) ;)
