P1000 31 in carnivores on p1000 with 2.5 super ATV
115,405
What is 2.5 superatv?
What exactly is your question? Need to be more specific!
links would help as well
Also, no pics of your rig yet either!
Pics Or It Didnt Happen!
Robobrainiac
Robobrainiac
2,550
8,957
Anything over 28 requires forward front arms. You will need 2.5" lift and forward arms to clear 31s. Wheel offset will be your next defining factor.
Best combo is to get superatv arms and adjustable shocks (an example is fox or rough country depending on budget) use the pre load on the shocks to achieve 2" of lift. Use the forward control arms from SuperATV.
Another option is c-fab arms with lift built in. Use whatever shock you want. OE or aftermarket.
After that start planning on other things like rhino axles, potentially control arm tabs or frame stiffeners if you want to go crazy.
Robobrainiac
Robobrainiac
2,550
8,957
I was not aware @SuperATV sold arms with lift built in. As far as I know they only sell forward arms.
As far as I know 31s will not fit without the mods I listed above.
115,405
Sorry 2.5 super ATV lift arms. Wanting to know if I install 2.5 atv arms will 31 Inc carnivores fit fine. Or are they to big
ah, Ok that makes sense now. Yeah that’s going to help you with getting bigger wheels on there. I run 30s and have no issues with those arms but I also have fox shocks that I can put preload on that has helped with it as well. Just the arms and no updated shocks 31s will most likely rub.
Don’t forget those pics
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
You can easily run up to a 31" tire with just these A-arms: https://www.superatv.com/honda-pioneer-1000-atlas-pro-1-5-inch-forward-offset-a-arms
Let me know if you're ready to pull the trigger, and I can get you a little forum member discount.
NOTE:
  • Pioneer 1000 or Pioneer 1000-5 Limited Edition Models will require Rhino 2.0 front axles
  • You may need wheel spacers when running 12” wheels
  • If you want to run offset A-arms with our 3" Lift Kit, you must have Rhino Brand Axles. Stock axles will bind
L
Lew84
21
NW Ohio
NOTE:
Wonder if you might be able to provide a discount code
russknight
russknight
1,910
7,510
Perry Florida
I'm running 31" Buckshot Mudders on 15" wheels with 1.5" spacers in the rear using SATV Arms. The front tires rub on the a-arms at full wheel lock but I avoid that by not turning the wheels to full lock. The back tires will scrub on the bed if you get into a severe articulation, but with my riding it's very rare.
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
That’s not a discount anyone would want. 😂
You sure?
Gloves on im ready
208,726
Me too!:rolleyes:
Reactions: Backwoods
