P700 700-4D Winch Install - Dual Use
NewHere2
NewHere2
Village Idiot In Training
46,153
352,797
High Plains of SD
I'm an Old Fart and with the lose of one arm, I depend greatly on my rigs to get me out of trouble when I have a "lapse in judgement". Generally I travel alone when scouting for critters (Think elk, deer, turkeys). Being able to winch off of the front or rear of the rig is important to me. So I decided to set the 700-4D up this way.
Installing a KFI front receiver was easy. Found it on E-bay, new but scratched, so made the seller a reasonable offer and they took it. I also mounted a rubber tube plug to keep it clean. Notice the red electrical quick connector mounted to the left.
MG 1778thumb17edfefca22f259f235103267f6d2679
A Warn VXR-35S was mounted to a homemade aluminum plate. The tongue on the plate is made from heavy wall aluminum. It's plenty strong enough and I would rather see the aluminum bend than damage the frame of the Pioneer. Went to E-bay again and found a set of Warn rear mount cables, think they were 10' in length. I used a 5ft. 8inch cable with quick connector for the front end. A 4ft. 4inch cable with quick connector was used on the rear. In addition, a 2ft. cable was used on the winch itself. The lengths of these cables would be determined by where you mount the winch contactor. I mounted my contactor under the passenger side seat. The winch and all my other lights and accessories are run off of a larger second battery ( already posted that info. ).
MG 1755thumbaff9be5979871ee01609ddd141d8ded5
MG 1756thumb2761dc140c623ff6f6532433a9fbc2af
MG 1767thumb2124a997b850fd01f6b0137b01b0876b
To store the winch when not in use, I installed an addition receiver up under the rear of the Pioneer box. Again, this is for storage only, too much leverage up that high and could result in frame damage if pulled from there.
MG 1753thumbb90f36a17b330b295e4810de6bb1fdb8
MG 1754thumb4cb859f61393f4299f79c9e9cd717274
MG 1765thumb40b78e6e9b0347697d2a01acd796130e
MG 1769thumb880dd2296667ea88dd4e7b5d3b6dfc9a
MG 1873thumbd806e96817b8450a8e0d62f9c407eda2
As a plus, the winch when stored stays relatively high and dry!
PS
My 7yr. old Grandson and I started work on an aluminum front rack for the 700 (or "Buggy" as he calls it ). Hope to have it done by mid week. Damn this virus crap. I've been doing home school and daycare with him since this started. My thoughts and prayers go out to all of you!
BillEwing
BillEwing
80
125
kingston springs tn
The flexibility is awesome with what you have done here. I installed the same type of winch rear hitch mount set up on my Chevy Z71 truck a few years ago. I used the Warn Xd9000i with a cradle mount pictured in the link. I did not purchase it from this vendor but it is the same set up and still works great today.
NewHere2
NewHere2
46,153
352,797
High Plains of SD
Yep, It's the best of both world's. I have my Elk Hunting Suburban set up the same way. Have had occasions where one winch is buried and not usable. :( The movable winch is an older 10,000 lb unit. I also carry a 3500 lb winch with 2 extra pulleys.. Have had instances where both winches were used at the same time. :confused: One winch pulling forward, the other at 90 degrees to pull the suburban sideways at the same time. o_O When you double line the 3500 lb winch it will do a lot. :)
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
Genius !
I'm loving this.
Don't ever put that winch in the factory 2" receiver. You will rip it out. Ask me how I know.
Gator
Gator
2,488
10,464
Louisiana
The trailer hitch on the 700 can carry a trailer pretty well.
It doesn't like upward loads. People using plows have torn theirs. I dropped off in a hole at Mulberry. I had my son winch me out backward. Didn't seem like he pulled hard at all. But when I got it cleaned off, the receiver was broke/torn loose. A piece of angle iron and a couple of welds, it is stronger than new.
Not very entertaining. I think I'll add strippers to the story next time I tell it.
