700 pioneer
CTO
Texas
My 700 pioneer won’t shift into 3 rd. Sometimes won’t shift well into 2 unless I let off gas. Anyone know what I need to fix?
Reactions: TxDoc and Smitty335
115,818
First of…Welcome from Michigan.
what year and miles?
Check your wire connections and make sure your battery has a full charge.
second…PICS OR IT DIDNT HAPPEN!
Some p7 guys on here might be able to help you
Dance Man
Dance Man
16
East Grand Forks, MN
Let the engine run for five minutes and see if that makes a difference. That’s what I have to do with mine.
43,292
1st thing to do when a 700 miss behaves when shifting is to check the oil level using the procedure laid out in the owners manual. Run it a skosh over full.
Thorney
Thorney
101
382
Minnesota / Wisconsin
I'm finding out with my 700-4 that oil and temperature make all the difference in the world. Trying to shift in and out of gear with cold engine you have to really slam it. Warm engine / oil and it is like butter. Same thing shifting gears. After it is warmed all the way up it is smooth. Cold shifts are like whiplash. I can only imagine how testy these machines would be with low or dirty oil...
