P1000 8” portals. What’s smallest rim size
JenElio
JenElio
82,846
718,098
Loxahatchee, florida
I would think 8” portals would need 8” rims. Maybe go to 9” if you want a little clearance for pebbles.
amirite @SuperATV ?
🤔..........I'm gonna go out on a limb here and say no. Stock set up need at least a 12" rim to clear hub/rotor/caliper etc. Adding a 8" portal means you have to clear a bunch of more stuff mounted to suspension. I'm no expert but I think somewhere I read the 6" portals needed at a minimum a 15" rim...........I'd think the 8" portals would probably need around a 18" rim to clear. I'm sure @SuperATV would know for sure being as they are the only ones making the 8" portals (I think)???
Reactions: ChadD
116,574
He can run Lawnmower wheels with 6“ spacers in there! TaDa!!!! 🥳
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
It says 22” wheels minimum. But superatv visits this forum pretty regularly and will know the real answer
BA7CCB4D 6B55 49E4 9C56 D52F39F0A5DE
B7A0F7E5 772B 4370 B12D 5CAA7CE865AC
