Huntndogs
I wanted to carry the spare 31x9.5 as low and far back as possible. I have the stock cage and did not care for all the mounts I had seen until I found the Pro Armor UTV jack and hold down set up. I replaced the webbing it came with with wider webbing and also changed the tie down points instead of the hook system it came with. Holds the tire very firm in the bed and the platform make the scissor jack very stable on relatively flat ground. (I am in the desert southwest) There is room in the back corners of the bed for my tool roll and a tow strap and I can strap my soft cooler to the platform behind the jack. I have not tested in the desert yet, just too damn hot. Just thought I would share the option....
