P1000m3 adding second winch
sureshot
Pittsfield IL
I am installing a second winch on my Honda Pioneer 1000EPS above the bed on roll bars and wanted some input on where to add a second battery under the seat or in front in extra battery compartment not sure how the wiring would work the best so any information with this would be great I don't know if anyone has done this on here or not I am new to this site like I said any advise on battery type or wiring type would be great
Reactions: ghost
Either way isn't too bad. If you place the second battery under the hood, you have a short run to connect the two batteries and can use a battery isolator to protect the oem battery. Also, you can use a battery "joiner" to connect the two batteries only during winching so your voltage doesn't drop.
On the other hand, you can put one large battery under the drivers seat like an Optima yellow top. This one battery would be enough for all accessories and winching but wouldn't give you a back up battery like the dual system does when used with an isolator. However, you can carry a small jump pack in the glove box for emergencies.
As for the wiring with the battery under the seat, nothing changes under the hood. Just run a large gauge wire to some remote terminals in place of the oem battery.
Reactions: ghost
ghost
ghost
993
1,874
BC
What he said ^^^
My second battery is under the hood. I would do it again.
I;m saving the under the seat area for something special - but I dont know what that is yet.
It would be great if post some pics of your second winch install.
Reactions: cwalton
sureshot
Pittsfield IL
thanks for the input ill have to give it some thought if I put it under the seat i just know ill wish i hadn't later
sureshot
Pittsfield IL
What he said ^^^
when I get it done I will post some pictures i am waiting on parts still
