I am ordering winch mounts and Warn Provantage plow with all the mounting hardware. In what order should I assemble all of it. I am putting it on a pioneer 520. Thanks in advance for your advice.
I also broke a synthetic rope and went back to wire rope. My synthetic rope lasted about the same time as yours.I would put the winch mounting plate on first and then assemble the machine specific mount, then the winch and then the plow and plow mount. The winch needs to be moved for easier installation of the machine specific plow mount. I would use wire rope and avoid the synthetic rope. I broke my rope after about three hours of use and am now restranding the son of a gun. I should of went with the wire rope like I used on my rancher..
What synthetic line are you using? I think my problem was the synthetic line I was using was for an ATV winch.Snapping ropes has more to do with the Warn setup than it does the line IMO. They made it more complicated than it needed to be based on where they placed the winch. Connections and hardware down low in sh**y conditions means more points to fail. Mounting the winch up high keeps it stupid simple.
Six yrs plowing on a synthetic line and had to replace it once. Blame myself though for leaving the hawse fairlead on. But the knot I tied in it kept me going until the new one showed up.
Everyone's got their own thing though, happy plowing season.![]()
I got 12 years out of the synthetic rope on my Honda Rancher with a Warn setup, but it was a smaller plow than you would run on a SXS.Snapping ropes has more to do with the Warn setup than it does the line IMO. They made it more complicated than it needed to be based on where they placed the winch. Connections and hardware down low in sh**y conditions means more points to fail. Mounting the winch up high keeps it stupid simple.
Buying a Honda 2022 Pioneer 520 and want to get a winch and plow for northern climate here until we move. Do I have to buy the Honda OEM winch mount and plow tube connectors etc? Or can I go to KFI and buy their stuff for less?
Ron
Great. What size winch should I get? It has to be much less expensive right?
