Aftermarket brake rotor.
atvsnowman
atvsnowman
23
I need to replace my brakes. I want to change the rotors also. I this will improve the life span as the current rotor has about 3000 miles on them and have become grooved.
Has anyone found any other aftermarket rotors anywhere? I could only find these 2 + OEM ones.
I may just go back with OEM Factory rotors run $50 each. Part # 45251-HL1-A01
I have only found the following one on ebay.
- 4 Stainless Steel Brake Rotors on ebay for $180 (solid, no holes)
I also seen this one at $115 each rotor but I'm not paying that.
- 1 EBC Brake carbon steel, zinc plated Rotor for hole ported.
Rotor1 640x480
Rotor2 640x480
greenatv
greenatv
127
32
I would no go with the solid rotors.
and I defiantly would not pay $115 for 1 rotor.
I agree with you, after a few thousand miles it is a good idea to change the rotor with the pads. I'm sure you could get them turned but how much would cost.
So.. Order the factory ones.
Similar threads
