The Gorilla 8017 Motorcycle Alarm with 2-way Pager is serious protection for motorcycle enthusiasts that want the ability to keep track of their bike's security at all times. Along with all the features and hardware found in Gorilla's model 8007 motorcycle alarm--including adjustable 120db Piezo siren, 3-button remote transmitter operation, 100% waterproof construction and quick easy installation--Gorilla's 8017 alarm system also ships with a 2-way pager. Every function of the alarm can be monitored on the pager's LED screen from up to 1/2 mile away.
The Five-Tone Adjustable Siren
The Gorilla 8017 protects your bike with the power and volume of an adjustable 120db Piezo siren. Preset at the factory to emit five separate tones in sequence when tripped, this siren can also be quickly customized with a push a button to emit a single tone that you prefer. The easily installed siren accepts and stores over 500,000 possible code sequences randomly generated by this transmitter, and with convenience in mind can be used with up to three separate transmitters.
Other valuable features include a false alarm circuit that can shut down the sensor registering the event after the fifth false alarm, preventing unnecessary battery drain, a panic feature which allows the transmitter to activate the alarm's siren from up to 100 feet away in case of an emergency, and a LED light that serves as both a system status indicator and a visual deterrent to would-be thieves. The alarm also allows owners to choose from seven levels of sensitivity, which drastically reduces the chance of false alarms in busy and loud areas, without compromising security.
Powerful Triple Sensor Protection
Although the Gorilla 8017 is one of the most compact motorcycle alarm products on the market, it is also one of the most effective thanks to the strength and flexibility of its three built-in sensors. These include tilt, shock and current sensors. The tilt sensor, set while your motorcycle is at rest with its kickstand down, is designed to alert you when your bike is pulled upright while the alarm is set. The 8017's two-stage shock sensor monitors any disturbance, jolt or impact to the motorcycle, indicating a light disturbance with a single sonic chirp, and stronger disturbances with an alarm for a full 30 seconds. Finally, the current sensor scans for anomalies in the electrical system that can occur, for example during a hot-wiring attempt, activating the siren in those cases.
The Added Security of Two-way Paging
Working in conjunction with a two-way antenna connected to your alarm, the 2-way pager included with the Gorilla 8017 Motorcycle Alarm is designed to alert you when any of the 8017's sensors are activated. This includes the tilt, shock and current sensors, as well as any "Warn Away" shock events. This allows you to stay aware of what is going on around your bike from up to a 1/2 mile away. Just as with the standard remote transmitter, the 8017 system will accept signals from up to three pagers. Used in conjunction with your included standard remote transmitter, motorcyclists are ensured of maximum security, 24/7.
Features
• Powerful five-tone, adjustable 120db Piezo siren
• 3-button remote transmitter operation
• Compact 2-way pager with 1/2 mile range included enabling owners to always know the security status of their bike
• Maximum security via the included tilt, shock and current sensors
• Adjustable shock sensor with seven levels of sensitivity to match your surroundings
• Programmable five-tone siren allows you to pick the siren tone you want
• Warn away mode sounds warning prior to full alarm activation
• 100% waterproof
• Panic feature enables you to activate the alarm siren from up to 100 ft away
• Includes everything needed for a simple, quick installation
• LED warning light for system status and theft deterrent.
The Gorilla Automotive Motorcycle Alarm with 2 way Pager is serious protection for motorcycle enthusiasts that want the ability to keep track of their bike's security at all times. Along with all the features and hardware found in Gorilla's model 8007 motorcycle alarm including adjustable 120 decibel piezo siren, 3 button remote transmitter operation, 100 percent waterproof construction and quick easy installation. Gorilla's alarm system also ships with a 2 way pager. Every function of the alarm can be monitored on the pager's LED screen from up to 1/2 mile away.
This is how I mounted alarm. Sorry about the mud.
