P1000 Aluma Owners
Farmer
Farmer
2,916
16,781
Southern MO
Mine's mounted on the hitch with a u-bolt from the trailer dealer. I added some rubber shower pan liner between the bolt and the aluminum. It lays flat. I'll try to get a picture next time I walk past it. It kind of makes the tongue heavy when your moving it around by hand but no big deal.
Reactions: Lady01
sporter
53
44
Elkhunter
Elkhunter
345
453
Minnesota
My spare is steel. It definitely does add some tongue weight. I have a tongue jack with a wheel so it is easy to move around by hand.
Reactions: sporter
P
pappyo
597
2,400
I've done a couple Aluma's
Right stake pocket ( when backing up Better see that side of Trailter )
1 Behind Right fender ( 8218 Power Tilt ) helps take a little Tung Weight Off.
1 in in Front of Right Fender ( 7818 with Ramps )
Both Home Made Mounting Bracket to fit in Stake Porcket & Hold Tire / Wheel.
20200111 110737 20200725 125538
Reactions: sporter
Sr56
97
289
53
Murfreesboro
I like that Aluma vertical spare mount.
Outsider here with a 10ft Featherlite trailer bought long time before the P1K5 came along. Would like to have 12 ft or 16 ft now.
5a9a1e5facb0b8a2a0a51224027069c3
I have a cheap u-bolt style and put it on the side. I can still use my side pockets for the side rails when needed.
8dd4788646ccbbc5a3faba71deed9b47
Reactions: sporter
