P1000 Another tire/wheel question
Cjtwicks
Cjtwicks
Cottonwood California
Put my M1 Evils on on some new rims. Handles and rides a lot better.
5F3EF075 491B 405C 96D3 6F6367F077C0
Raynman
Raynman
Sudo Flotation device inspector
5,943
70,123
Thumb area, Michigan
Just so we know it happened! ITP 29” tires and 14” rims 9” wide on front and 11” wide on back. No rubbing whatsoever so far. Haven’t taken it out on the trails, but it handles sharp turns on the road without a problem. Just got it cleaned up today!View attachment 249558
Nice wheels and tires!
PJon
PJon
800
3,243
Arizona
After putting the tires on the rims tonight, because the rear rims are narrower than stock, the rear tires are just a bit taller than the front. Which is still opposite from what the stock wheel were. (Front taller than the rear). This still should be fine to run?
As stated, diameter matters. But when you’re looking at lowering air pressure to even things out, you’d be better off looking at circumference of the tire then divide by 3.1416 to get a true diameter.
Sking
9
25
Southaven, MS
How are the tires/wheels working out. . You may have saved me alot of money. I have 28x10x14 rock a billy tires and 14" wheels i purchased a few months ago. Rubbing at full pretty bad enough to want to rip plastic fender liner. What is the offset on the wheels and are you running any wheel spacers? Do you have a lift. I have a 3" lift. Looking forward to response on rubbing at full. Thanks
Reactions: Lady01
Sking
9
25
Southaven, MS
Also, are the tires the diff widths or are the wheels diff widths or both?
Reactions: Lady01
Sjc3081
Sjc3081
267
444
Wappinger NY
I have 28/10/14 Rockabillies @ 8psi 6+1 front wheels 5+2 rear wheels no rub at all, even full lock ,compression in reverse. 16 psi of air they rub at full lock and compression.
Reactions: Lady01
Cjtwicks
Cjtwicks
I have 28-10-14 M-1 Evils 8 ply all the way around @10 PSI
I don’t have any offset and I’m not running any spacers and I have no rubbing or any issues. I have put it through it’s paces and when I have some wear all just rotate them.
Reactions: Lady01
TripleB
TripleB
21,175
184,138
Caryville, Tennessee
The wheels have to have some type of offset.
212,881
I never rotate, last thing I want is worn tires on the steering axels, I can put up with it for a little on the back, a very easy way to wear front and back fairly even is to run in 4 WD on trails?
Reactions: Lady01 and Isaiah
