P1000 any pros or cons on this radio setup.... boss...
TripleB
TripleB
15,250
136,198
Caryville, Tennessee
I just did not want to spend more than 250.00 or so...do I need a preamp or better speakers...also how did you mount your speakers? so many items to get next...
https://www.amazon.com/BOSS-Audio-MGR350B-Marine-Receiver/dp/B00VV6Y7O2/?tag=sxsweb24-20
thanks in advance,
Gary
I have the same radio. It's been working for a year and does what I need. I have 4 of these speakers in my 5 seater. https://www.amazon.com/gp/aw/d/B00VV6YQAW/?tag=sxsweb24-20. 2 on the middle top bar and 2 on the rear bar. Plenty of sound for me but I listened to mostly country. If u like to jam I guess a amp would be a good idea.
Bad_bowtie
Bad_bowtie
Huge member
2,547
15,690
East Tennessee
I have that same radio and the same 4 speakers set up just like you do. While it doesn't compare to what alot of these guys run, I'm perfectly happy with it also.
60,382
thanks in advance,
Gary
I've got the same radio and speakers as well with no issues other than the radio screen will get a little moisture in it from time to time. More than likely just the humidity down here in the swamp that causes it and it's never gave me any problems.
rickoshea
i have that one in my boat with just 2 speakers.sounds good without an amp.sounds terrible and will make my ears bleed if it plays country music though.if it's playing anything else it's ok.
Dirtstiffs-1000
Dirtstiffs-1000
1,657
6,034
hondasxs.com
I did this and it sounds pretty good without an amp. I'm using 2 Polk Marine 651 - 6.5 " speakers in wake cans, mounted to the rear roll bar.
I might throw an amp and 2 speakers up front later. Plenty loud and clear sound with just the rears.
No moisture issues but I think mine has small pin hole vents on the side of the lense covers. Or maybe I did that.. 6 months now, no issues.
20191026 170832
20191102 174521
sheba4
161
197
mn.
  3. Big Red
View attachment 172715 View attachment 172716
nice setup...do not let that farm jack fall on you? all I need to do is with the radio in...any help would be appreciated. iam not a wiring guy..
thanks,
Gary
Reactions: toddvdh
sheba4
161
197
mn.
  3. Big Red
ok thanks, that is what iam going to go with. now I just need help in wiring it... iam not good at wiring... how did you do yours?
thanks,
Gary
Reactions: toddvdh
sheba4
161
197
mn.
  3. Big Red
was it hard to wire, I need help on this. I am not an expert when it comes wiring...
thanks,
Gary
Reactions: toddvdh
rickoshea
make sure you wire the yellow/red wire to a key on power source or it will not function properly.the red can go directly to the battery or power block .other than that it's really straightforward.
Reactions: toddvdh and TripleB
sheba4
161
197
mn.
  3. Big Red
ok I can do that.. did you install another fuse box under the hood? also I will be putting a winch on and another battery to help with accessories..
Gary
Reactions: toddvdh
Sheetmetalfab
Sheetmetalfab
2,176
13,614
Alaska
country music does that to every single radio on the planet.
makes me want to pierce my eardrums.
  • Haha
Reactions: toddvdh
bumperm
bumperm
1,899
6,778
Gardnerville, NV
We all have a short comings, weaknesses and failures. I feel so badly for you. Have you considered country music immersion therapy?
