P500 Anyone build there own 520 rear bumper
Parttime
Parttime
44
262
53
West Monroe La
Remove the heat shield bolts. Use a a file or dremel to remove the threads where the bolts go through the frame. My bumper is 1 1/2 x 3 tube with 1 inch square tube to mount to the 500. After I removed the bolts and cleared the frame from the threaded part for the heat shield bolts. I put the square tubing in then figured out how far I needed my bumper to stick out. Then tack welded everything up. Then I marked the heat shield bolt holes and drilled those out into the 1 inch square tube didn’t have to go all the way through just the top side. The sides that run into the frame extends inside about 8 inches or so. I used 1/4 or 5/16 bolts to mount the bumper through the frame. Hopefully this gives you an idea of what your looking for. Good luck
F0812E2E 5CC6 46C2 B8FB A0B60B871002 24AB18F5 B2CA 4E01 A7C1 74D6E9C49CC2 9CD3ABD8 5A3F 4115 9853 A10A09930698
Reactions: crewcabrob
