Anyone with an AC WD engine?
Glock21user
Glock21user
1,820
9,056
Livingston county, Mi.
Ok I admit this is a weird topic for a SXS forum but hey what the hell.
I am looking for an Allis Chalmer Wd/Wd45 engine some one may have still in the tractor or maybe in a barn.
If you have anything and want to part with it let me know.
Thanks y'all.
Vikes79
Vikes79
SKOL!
10,826
105,031
South Dakota
Thanks y'all.
Wish i had one around in a condition to help you....but I like mine as is...
900B8E1C 573A 4CDE 84D7 A35F8E0B6349
Seriously I just scrapped a set of good pistons and sleeves as I couldn’t find a home for them for 3 years.
I restored mine 5 years ago. I’ll send you a pm of where a good starting location might be.
Anything specific you are looking for (crank, etc)?
Glock21user
Glock21user
1,820
9,056
I let a friend help me do food plots last year he lugged it too low in 3rd with a 2 bottom in sand soil and broke a rod which made a nasty hole in the pan.
So a running engine would be my best bet to get work done quickly this year.
20200420 1943340 20200420 194349
wrhii
wrhii
302
1,757
Florida
View attachment 201072 View attachment 201073
Road many on one of those. Dad had 4 of em with the hand clutch. I always wanted the D17 instead, it would make "smoke"!!!! 😁 😁 😁
Reactions: Glock21user
Glock21user
Glock21user
1,820
9,056
They definitely work well outside of their size.
I like them for working tight areas in the woods.
wrhii
wrhii
302
1,757
Florida
[/QUO
Thanks y'all.
I'll look around down here. Theres a guy in Zolfo Springs that may have or know who to hook you up with.
Glock21user
Glock21user
1,820
9,056
Well after a little work and some windshield time I not only have one but three complete running engines.
500 for all 3.
One is in the tractor and running one is on a homemade test stand and one is hanging in the barn on the crane ready for a teardown.
Here are a few pics of the stand we made.
CMB
CMB
5,108
55,090
  2. Talon X LV
500 for all 3.
View attachment 207578View attachment 207579
Send me a PM when you see this. I know where 1 is for sale. See if its worth getting .
Reactions: Mopower58
Vikes79
Vikes79
SKOL!
10,826
105,031
South Dakota
Nice!
AC made a crap load of WD’s and WD45’s they are still doing a lot of farm work. A lot of organic farm startups are snapping up the old AC equipment.
One thing to watch is the frost ( sand casting) plugs in the head. Not keeping fresh antifreeze in the block will eventually drive the coolant pH down and start corroding the plugs in the head. When they go, the coolant dumps right into crank case leading to a milkshake mess and mucho badness. That’s what happened to my 45.
Before you put the working motor back in, a seal kit is super cheap and worth it. The oil pan and rear main is a bit tricky but doable. Personally I’d pull the head and check it, and install new plugs. Really not necessary to deck the block or head unless it’s really bad.
At least pull the valve cover and make sure the ends of the rocker arm tubes are still plugged. The AC motors of the day used bypass oiling and if the rocker arm tubes aren’t plugged, oil won’t make it to the rocker arms.
These tractors were made to be OH by the farmer under a tree. That’s what’s so awesome about them.
CMB
CMB
5,108
55,090
  2. Talon X LV
I still have your #. I'll write it down and I'll try to go by his home this week and give it to him
