When you drive this at home
Then you come to work and drive this piece of sh1T.
I will say the horns from the farm did help it.
I'd much rather drive a Kubota than a Pooplaris hahaI know how you feel. I have a Kabota at work.
I wanted the dark grey but they didn't have any when my wife went and picked it up. She looks sharp hereThe white is really sharp looking.
Pro Armour Crawler XG's 30x10x14 and MSA M31 Lok2 beadlocks 14x7'sLol.. that's funny!
I like your wheels and tires. What are you running?
Do you know the offset of your bead locker wheels? I just ordered to 12"x8" (4/4 offset) Method bead locker with 28"x9"-12 front and 28"x11"-12 rear. I'm looking for a much wider stance than stock. 2" highliftPro Armour Crawler XG's 30x10x14 and MSA M31 Lok2 beadlocks 14x7's
I have absolutely no complaints on any terrainNice how do like the crawler tires
If I'm not mistaking they are 0 offsetDo you know the offset of your bead locker wheels? I just ordered to 12"x8" (4/4 offset) Method bead locker with 28"x9"-12 front and 28"x11"-12 rear. I'm looking for a much wider stance than stock. 2" highlift
Run 7psi in them and it's a smooth rideNice how do like the crawler tires
Yes I have the highlifter lift with the highlifter a arms and wheel spacers to make up for liftI'm a novice. I can't tell if you have a lift. Looks great!
Yes Highlifter lift and max clearance a arms and running spacers to get width to make up for the liftI'm a novice. I can't tell if you have a lift. Looks great!
